Changing clutch fluid
Old Nov 26, 2011 | 02:15 PM
beerformeplz's Avatar
beerformeplz
Cruising
Default Changing clutch fluid
Just tried using the Ranger method. My question is before changing the fluid it was almost black with dust in it. After adding new fluid and pumping the clutch pedal about 35 times the fluid still looks brand new. I know there has to be more dirty fluid in there. I even drove it for about 5 mins and rechecked it and the fluid still looks brand new. My question is shouldnt the new fluid mix with whatever is in the lines and show dirty in the resovior after only one change?
Thanks.
Old Nov 26, 2011 | 02:18 PM
98DC231's Avatar
98DC231
depends how bad your situation is. go beat on the car and check it.
Old Nov 26, 2011 | 02:21 PM
beerformeplz
Cruising
The fluid was REAL bad. I would think it would like nasty again just after a brief drive.
Old Nov 26, 2011 | 02:26 PM
hotwheels57's Avatar
hotwheels57
Don't look a gift horse in the mouth.
Mine wasn't black, but it was a honey/murky colored...with only 3,800 miles on it. I figured it would take a few R&R sessions to clear it out. Nope. One complete change with the turkey baster and about fifty pumps and it was still clear. That was three years ago.
Old Nov 26, 2011 | 02:33 PM
beerformeplz
Cruising
LOL, thanks. I know my luck and nothing ever goes this well.
Old Nov 26, 2011 | 03:16 PM
lucky131969's Avatar
lucky131969
Thanks.
Unless you are willing to bleed the system, you can't replace all the fluid.
Old Nov 26, 2011 | 03:42 PM
bumble-z's Avatar
bumble-z
You need to drive it with some hard (high RPM) shifting.
If your fluid was like you discribed, believe me you have several more resevoire change outs coming your way.
Good luck.
Old Nov 26, 2011 | 04:10 PM
beerformeplz
Cruising
Good luck.
Old Dec 3, 2011 | 09:48 PM
ronssito's Avatar
ronssito
Just did mine using the Ranger method and the pedal effort has been greatly reduced.
I'm sure it's the 1st time the fluid has been changed on the 12 year old C5.
I'll be monitoring the fluid color regularly now ...
Old Dec 4, 2011 | 05:16 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks.
You have to bleed the system from the bleed screw located at the slave cylinder in order to replace all of the fluid in the system.
Old Dec 4, 2011 | 09:16 PM
m6 c5's Avatar
m6 c5
Yes but particles move from areas of high concentration to low concentration, as with fluid and water so you can do a pretty good job if you change it several times.
To Changing clutch fluid
