Please Help: REDUCE ENGINE POWER, TRACTION CONTROL FAILURE (with Codes)
I was driving home in my 2003 Z06, had the stock bose stereo blasting...got on it fairly hard in 2nd gear leaving a stop...then all of a sudden I felt a cut in power (couldn't tell if it was from the TC or the engine). I immediatly pushed in the clutch and was coasting about 55-60mph...where I saw the dreaded "Reduce Engine Power" and something like "Traction Control Failure" or "Service Traction Control" error messages. I continued to coast, took the next turn and pulled over.
As I pulled over I could hear that the car sounded strange at idle (as if it were missing and the idle was somewhat elevated). I immediately shut off the car, waited about 10 seconds, fired it back up and all seemed fine/normal (except the check engine light is now permanently on). I cruised home slowly on the 25mph back roads, got home, parked and promptly got on the Corvette Forum.
I found multiple posts of others dealing with these same error messages, read up a bit then went out and collected my codes.
Unfortunately, I shut off the car before I collected these codes...I have never collected my codes or reset them before. Here they are:
10-PCM = P1514 H
60-IPC = U1160 H
99-HVAC = B0361 H
AO-LDCM = B2282 H, B2284 H, A1064 H
A1-RDCM = B2283 H, B2285 H, U1064 H
28-TCS = C1278 H
Can anyone help me with these?
Since pullling the codes, I started the car again and it seems to run fine, albeit the check engine light is on (and it seems that the idle could perhaps be a tad bit higher/elevated over normal). I have not driven it again yet.
Also here are my primary mods, if it matters:
243 ported/shaved heads, cam, headers, polished TB, pulley, Calloway honker, tune
Thank you for your help/input.
MotoJB
Thanks Blownbluez06...truly appreciate your response.
So - anyone else out there? Any other thoughts/suggestions?
Please and thank you.
