Replacement clutch
Old Nov 28, 2011 | 02:05 PM
fendermender's Avatar
fendermender
Default Replacement clutch
OK, I been searching for 1/2hr and all I come up with is upgrades. I have the engine out and decided to look at the clutch...71,000miles. Still a lot of material on the disc but the flywheel has some nasty looking hot spots. From what I read those won't go away with surfacing.
Anyway, I figure yet another may as well. Who knows, it may have lasted another 70K but I had to go and look. Not really looking to upgrade if it costs more than stock. No plans for engine mods or racing. Are the Brute Power ones Rock Auto sells any good? They show two different ones but no explanation of the difference. Anyone know the part#s for an LS6 setup? I can buy from my dealer at wholesale through my bussiness but they look everything up by VIN.
Thanks, Jim
Old Nov 28, 2011 | 02:09 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
dunno about the one you mentioned but the LS7 setup is working fine for me
Old Nov 28, 2011 | 03:46 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The LS7 clutch is an excellent replacement for a stock to moderately modded Vette.
Old Nov 28, 2011 | 09:07 PM
feeder82's Avatar
feeder82
ls7
Old Nov 28, 2011 | 09:18 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Check out the ECS Mantic Single Disc...alot lighter than the heavy LS7 clutch kit..pedal pressure lighter than stock with butter smooth engagement, zero chatter!
Old Nov 28, 2011 | 09:45 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
http://forums.corvetteforum.com/c6-f...n-special.html
Old Nov 29, 2011 | 11:38 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
LS7 clutches are 10lbs heavier than stock LS6/LS1.
I went with a Monster Stage 2 clutch with there light weight flywheel (7.5lbs lighter than stock LS6/LS1).
I immediately felt the lighter rotating clutch. Car felt more nimble and responsive.
I would not want to feel what 10lbs added to the clutch would feel like...
There are numerous lighter clutches out there. if your going to change your clutch .... get something that will give you a performance boost too.
Or you could just sick with getting a LS6 clutch. It should last you at least another 70K miles. And your not adding rotating mass.
Toque
Old Nov 30, 2011 | 01:49 PM
SNL/MonsterClutchCo's Avatar
0SNL/MonsterClutchCo
Former Vendor
Our Monster Level 2 is hard to beat.
Take into consideration that the LS7 doesn't come as a complete package and doesn't have a one year warranty. All of our components are tested and proven to do exactly what they say they will do, no questions. Our customer service is absolutely second to none and our reputation speaks for itself.
Oh, and did I mention we've got them on sale?
http://www.monsterclutches.com/shop/...5-package.html
Don't forget to add bolts and bleeder, we offer three different bleeders ranging from $19.99 - $49.99 and our bolt kits are $24.99. This would be a complete swap with no headaches! These parts are found in the misc. parts section of our site.
Let me know if you have any further questions.
Steve A.
Owner/Operator
817-750-2000
steve@monsterclutches.com
Old Nov 30, 2011 | 01:50 PM
Former Vendor
Toque
Thanks for the continued support Toque!!
Old Nov 30, 2011 | 03:07 PM
fendermender
[QUOTE=Toque;1579346580
Toque[/QUOTE]
Thanks, I've ruled out the LS7. Any part #s for the LS6? Will it work with the stock LS1 hydraulics? I may go that route if it comes up the same price as the OEM LS1.
Old Nov 30, 2011 | 03:25 PM
Toque's Avatar
Toque
Gene Cully would likely have all that info. I do not... sorry.
Toque
Old Nov 30, 2011 | 08:17 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks, Jim
http://www.gmpartsdirect.com/catalog/frameset.cfm
Old Nov 30, 2011 | 08:25 PM
81c3's Avatar
81c3
Monster Level 2 I would suggest using this set up to support any future hp upgrades. Its a great street clutch and will support 500hp/500tq Always upgrade when you have the chance and especially where the clutch is concerned. The only device transfering the power from the engine to the rear wheels is the clutch assembly, why wouldnt you upgrade it?
Old Nov 30, 2011 | 09:01 PM
fendermender
Those sites don't list part numbers.
If you read my OP I thought I explained I'm not looking to upgrade for more $$$. This one has 71K on it and surely would have went more easily...but while it's apart thing. If I get one that goes another 70K with me just tooling around...heck I may be dead by then. Thanks for the replies.
Old Nov 30, 2011 | 09:09 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The do if you ask. You stated you were looking for an OEM LS1 or LS6 clutch, that is what they sell. Just over 400 for the LS6, just under 300 for the LS1.
Old Nov 30, 2011 | 09:12 PM
Toque's Avatar
Toque
Monster says the Stage 2 will hold 550rwhp. That's what I was told anyways.
Toque
Old Dec 1, 2011 | 12:08 AM
Chaplain's Avatar
Chaplain
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Thanks, Jim
Old Dec 1, 2011 | 08:48 AM
81c3's Avatar
81c3
Toque
yea, I knew it was a minimum of 500/500 so I thought Id be conservative.
Old Dec 1, 2011 | 09:17 AM
fendermender
Really?? My dealer quoted me $412 (my wholesale price) for the stock LS1. That's disc, PP and flywheel. He said GM sells the PP and flywheel as a unit with only the disc being sold separate. I have not seen any three piece set for under 300 anywhere. Perhaps I shall call.
To Replacement clutch
