driver side door lock
Old Nov 29, 2011 | 01:13 PM
8888vette's Avatar
8888vette
Default driver side door lock
Guys;
i have read lots of treads but still not sure of my problem
i fob will open the passenger side door and trunk the only way i can lock and unlock my driver door is using my key is this a relay issue or my door actuator is dead......
thanks
Old Nov 29, 2011 | 02:11 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do you hear the relay click inside of the door control module? If the relay is bad, you can supposedly swap the door control modules to verify, but you must put them back as they are not the same. Most likely, the relay in the module is the issue but check all the fuses first to be sure its not a power issue. I've never heard of the solenoid itself failing but its possible of course.
Old Nov 30, 2011 | 10:26 AM
8888vette's Avatar
8888vette
i dont hear no cliking coming from the door i will check fuse 33 also i have a LDCM code on the DIC
THANKS
Old Nov 30, 2011 | 02:26 PM
8888vette's Avatar
8888vette
i check fuse 33 was ok i then press the lock/unlock buttom passenger side i do hear a click i also check for any codes and dint show any.
thanks
Old Dec 1, 2011 | 07:43 AM
8888vette's Avatar
8888vette
8vette7
my bad the ldcm shows 0 codes and the issue is the driver side like i mentioned before i do hear the cliking everytime i touch the unlock button.
Old Dec 1, 2011 | 08:04 AM
dgrant3830's Avatar
dgrant3830
Time to open the door panel and use a meter to see if power is actually getting to the solenoid or not. If not, then a bad relay in the door module.
Old Dec 2, 2011 | 01:53 PM
Scooter70's Avatar
Scooter70
Mine did the same thing and it was the relays. Do yourself a favor and replace both the lock and unlock relays. They're cheap.
Old Dec 3, 2011 | 11:30 AM
hiyosilver01's Avatar
hiyosilver01
Hello,
I am trying to hijack this thread but what are the part numbers and where can we get them? Thank you.
Old Dec 3, 2011 | 10:13 PM
jacobsjp's Avatar
jacobsjp
Originally Posted by hiyosilver01
Hello,
Here's a write-up with part numbers....
http://www.ronjpics.com/Corvettestuff.htm#DCM
To driver side door lock
