Popping Noises
Old Nov 30, 2011 | 02:28 PM
elopez1986's Avatar
elopez1986
Default Popping Noises
I have a 2002 Corvette with long tube headers, x pipe, axle back, hi flow cats, and cold air intake. I recently dyno tune the car and was told that it cant be fully tune because the of some random misfires. I am expiriencing popping noises when accelarating quickly and at high RPM. The popping noise makes the car slugish and rough to ride. About a year ago I changed the spark plugs into NGK TR55 and granatelli wires with boots. My tuner tells me that the mechanical problems can be due to bad spark plugs, blaster coils, or ignition module. Does this sound correct? Help me. Thank you very much!!!
Old Nov 30, 2011 | 02:55 PM
Chicago1's Avatar
Chicago1
Pull the codes and it sounds like you need a better tuner.
Old Nov 30, 2011 | 02:58 PM
elopez1986's Avatar
elopez1986
Pull the codes? I had P0300 and P0153.
My tuner eliminated those codes.
Old Dec 1, 2011 | 11:42 AM
m6 c5's Avatar
m6 c5
I can see why he may have turned p0153 off but as long as you have your rear sensors in that place they should be fine but I see no reason at all why the p0300 code was turned off as that detects misfire and you should get a flashing CEL when that happens.
Did you pull the codes via the DIC?
Old Dec 1, 2011 | 11:53 AM
elopez1986's Avatar
elopez1986
I only have 2 oxygen sensors which are the one's before the cats (new ones too). The one's after the cats are eliminated. And yes, the codes were retrieved from the DIC.
Old Dec 1, 2011 | 12:12 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
broken valve spring, broken rocker, broken piston ring land, clogged cats, bad injector, bad spark plug, defective coil.
Those are the common causes of P0300.
Old Dec 1, 2011 | 12:58 PM
elopez1986's Avatar
elopez1986
I got my valve train checked by a mechanic who removed my valve covers and etc.
The cats are magnaflow hi flow and are new with less than 2000 miles
The spark plugs are NGK TR55 that were replaced less than a year ago
This leaves only the coils and injectors right?
Old Dec 1, 2011 | 02:10 PM
BLOWNBLUEZ06
and a broken ring land.
Those are just the common causes that I've witnessed.
Also doesn't mean you don't have a defective plug or wire or a plug with an excessive gap
To Popping Noises
