front fender removal.
Old Dec 1, 2011 | 01:47 AM
sccs's Avatar
sccs
Default front fender removal.
Hey, just a quick question.
i want to remove front passanger side fender(exterior body) for some reason,
where else are nuts except for top ones that can be seen when hood is open? i just dont want to miss any and brake the fender.
thank you!
Old Dec 1, 2011 | 06:05 AM
dougbfresh's Avatar
dougbfresh
Bottom and between the fender and front fascia.
Old Dec 1, 2011 | 06:11 AM
TriplBlk's Avatar
TriplBlk
Old Dec 1, 2011 | 08:08 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've not taken it off myself but during the assembly process at the factory, its the last main body part to go on, therefore it should come off fairly easy.
Old Dec 1, 2011 | 10:34 AM
SaberD's Avatar
SaberD
you are going to need to remove about half the fasteners that secure the fascia in order to clear the studs that hold the fender to the fascia. you will need to move the fascia out of the way before you can remove the fender. there is also a fastener or two on the inside of the fender near the cove you will need to remove.
Old Dec 1, 2011 | 06:33 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I know this is the wrong side, but there was a recent thread with some pretty good pictures for taking off the driver's side. I am not sure if the passenger's side would be similar.
http://forums.corvetteforum.com/c5-g...with-pics.html
Good luck.
PS. Take some pictures so we can see if it is the same or not.
To front fender removal.
