engine bay cleaning.. quick question
Old Dec 5, 2011 | 08:49 PM
bwill03z's Avatar
bwill03z
Default engine bay cleaning.. quick question
First off, before you guys slam me i did do a search and read up on it a little bit but I still wanted to get opinions. My engine bay is in bad need of a serious cleaning and I wanted to get some advice as far as spraying the engine down and what all to cover up, and how to cover it... I figured using a plastic bag or saran wrap would be best, but what all do I need to cover up? And has anyone had any major issues with spraying down the your engine bay with a garden hose? (using a light spray adapter of course)
Old Dec 5, 2011 | 11:53 PM
dndrsn's Avatar
dndrsn
I wash mine. Clean Engine
Old Dec 5, 2011 | 11:58 PM
Aerovette's Avatar
Aerovette
I have thoroughly doused mine but I cover the alternator with plastic. I am not sure where the knock sensors are but if they are under the intake like my truck, avoid that at all cost. Ask me how I know.
Old Dec 6, 2011 | 12:26 AM
Zeus-of-Boost's Avatar
Zeus-of-Boost
and the coil packs are easy to remove, i would remove them as extra precaution. it would also make it easyer to clean the valve covers
Old Dec 6, 2011 | 12:49 AM
bwill03z's Avatar
bwill03z
thought about doing that... is there any write-ups or anything on removing them? also, i dont have the cover over the battery compartment so should there be any concern with spraying that area?
Old Dec 6, 2011 | 07:30 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I have use a good strong cleaner like simple green and then just lighty spray it down. Just don't "blast" anything and you will be fine. When you are finished take a leaf blower and blow it off.
Old Dec 6, 2011 | 09:17 AM
Sinister-one's Avatar
Sinister-one
I was my engine compartment at the local car wash...... and then go home and wash the rest of the car by hand.
Old Dec 6, 2011 | 11:09 AM
printmanjackson
I wouldn't use a high pressure washer.
Old Dec 6, 2011 | 11:22 AM
Sinister-one
Been doing it for 3 years now, since I purchased the car. And have done it with all my other cars as well..... NEVER had a problem !
Old Dec 6, 2011 | 12:37 PM
dadaroo's Avatar
dadaroo
For the plastics, I use No Touch Tire Cleaner. Spray it when plastics are dry and then hose it off after a couple of minutes. It leaves an original finish and should last for many months/year unless you drive in the rain. I like it for plastics and tires since it does not leave a "shiney finish" which I don't like. Never had a problem on many Corvettes I have done.
Old Dec 6, 2011 | 12:44 PM
dadaroo's Avatar
dadaroo
PS: If your plastics have any "graying", use Back To Black. It is a miracle product you would not believe until you use it. It is normally needed for external plastics exposed to sunlight. Even on external plastics it lasts for months. It needs to be wiped on, unless you put it in a spray bottle. It is amazing because it is a clear product that you would never believe works like it does.
Old Dec 6, 2011 | 03:39 PM
craig04c5's Avatar
craig04c5
Nice post. Seems funny to spruce it all up just to put covers over it but most of us will do it!
Old Dec 6, 2011 | 03:54 PM
whiteboy444's Avatar
whiteboy444
Sweet!
Old Dec 6, 2011 | 07:26 PM
fendermender's Avatar
fendermender
Impressive. The before pics look much like mine. I've used basically the same Simple Green procedure on the Harley since it was new in 2000. No ill effects and it still looks new.
As far as the cover it back up deal...We wear clothes but still take a bath don't we?
Old Dec 6, 2011 | 10:43 PM
bwill03z's Avatar
bwill03z
good stuff guys thanks for the replies... so it seems like simple green is the most commonly used cleaner among the group... don't have at the moment but ill probably pick some up this week.
Old Dec 7, 2011 | 07:43 AM
Jewjenk's Avatar
Jewjenk
If I was buying a car and opened the hood and it was dirty or looked like it was just cleaned to sell the car=no deal no mater how cheap. Don't keep your car clean under the hood, then I assume that you trash it...........
Old Dec 7, 2011 | 08:09 AM
craig04c5's Avatar
craig04c5
Very true. A friend of mine is looking for a nice C5 Vert. He called me about a one owner 03 but said the engine was very dirty and had bird dropping stains in the paint. I told him to pass because the owner was neglecting it and probably not maintaining it.
To engine bay cleaning.. quick question
Old Dec 11, 2011 | 05:45 PM
bwill03z's Avatar
bwill03z
so i got around to washing the Z and cleaning the engine bay today... it was a success bc it looks much better now and more importantly the car cranked after i finished i used simple green for the cleaner and covered the alternator and a few connectors with plastic bags.. only thing i forgot to do was dilute the simple green with water :/ so i hope i didnt damage anything.... but anywhere here is a few pics. done have any before pics but it was pretty disgusting under the fuel rail covers!
http://i1118.photobucket.com/albums/...58/photo16.jpg
http://i1118.photobucket.com/albums/...58/photo15.jpg
http://i1118.photobucket.com/albums/...58/photo14.jpg
Old Dec 11, 2011 | 09:25 PM
Baldfart's Avatar
Baldfart
Looks great! I have got to do the same to mine.
Old Dec 11, 2011 | 09:48 PM
VETJAZZ's Avatar
VETJAZZ
Great info. I'm going to try it next week. Thanks.
