A4 LAUNCH
Old May 8, 2002 | 01:43 PM
MikeV's Avatar
MikeV
Default A4 LAUNCH
Has anyone tried launching from an idle vs. 1500 rpm against the converter, on the same day at the track? How did it effect 60' times and R/T.
Mike
Old May 8, 2002 | 02:37 PM
lostsoulny's Avatar
lostsoulny
Default Re: A4 LAUNCH (MikeV)
hmm would be interesting to see if anyone did back to back runs and could provide these numbers. if all goes well friday I should have some info to post :D
Old May 8, 2002 | 03:04 PM
MikeV's Avatar
MikeV
Default Re: A4 LAUNCH (lostsoulny)
Lost, I would be very interested to see the differance. Thanks for the help. Mike
Old May 8, 2002 | 07:38 PM
Face's Avatar
Face
As long as the traction is there, I always do best mashing it from a idle.
Old May 8, 2002 | 08:00 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: A4 LAUNCH (Face)
It hard to judge, but I have knocked off .05 -.15 depending on traction. With the PT-2400 it is hard to power brake and hold it at 1500 rpms without the car moving. A higher stall converter should not have a problem. The higher I take the rpms, the harder it is to get traction, the drag radials have to get really hot!
Old May 8, 2002 | 11:20 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
on drag radials I don't recall seeing much difference in ET or 60', however, big difference in RT which is more important to bracket racer.
Old May 8, 2002 | 11:44 PM
RWhite's Avatar
RWhite
Face, what wheels and tires are you using? I sure want some black rears for my black ‘Vette. I now have zero traction :D with my new 3500 rpm Vigilante!
Old May 9, 2002 | 10:59 AM
Face's Avatar
Face
Default Re: A4 LAUNCH (RWhite)
They're my old stock 98 wheels painted black with 275 series BFG drag radials. One was scuffed up, and I was curious to see how the car would look with black wheels. But soon I'll be in the market for either some matching wheels, or new ones all around.
Old May 9, 2002 | 01:27 PM
Mystery Fan's Avatar
Mystery Fan
With my Yank 3000, I can't see a difference in time either way on a hot day. I have tried many difference rpms and have the same results. On a cold day 60 degrees or less, my best results are to run it up to 1500 and let her rip. Drops the ET by .1, Usually I torque it to 1,500rpm on launch anyway because my R/T is better. I use 275/17" Nitto Drag Radials on my old front wheels.
A Friend has a Vigilante 3,500 and he swears by going from idle.
To A4 LAUNCH
