I can send him a link to this thread if you really want to get into it deeper I guess.
No offense, but I could care less. I just provided the info, because you wanted to know more, and to let others know that the terminals are available.......according to Power and Signal/Mouser websites.
I am just saying that if I am to believe the experts, this is incorrect. Either that, or you know more than the guys who do this for a living. I may be wrong in how I am describing it, but I know the bottom line was that it was not possible to get the right parts to repair the connector.
Not to sidetrack this thread, just want to make sure I'm clear on the failure. The electrical connection pins between the EBCM and body wiring harness somehow corrode and stop making reliable contact? What is the failure mode? I assume it will start throwing codes?
How do the connector pins/sockets get corroded? Is there any PM to keep them clean? TIA
EBCM failure is due to soldered joints failing internally. If you are skilled with a soldering iron you can try doing the repair yourself. Or you can pay someone to fix it like me. I can solder, but I am usually soldering wires, not circuit boards.
The harness/connector failure is not likely going to be an issue.
Okay now I'm confused, Luck131969y talks about terminals and the links to Mouser are for terminals. Doing the PCB repair on the circuit board is something altogether different. I have lots of experience on PCB repairs and would have no issues making these repairs or the terminals for that matter. Just unclear on what the common failure mode is.
We are talking about 2 different issues. The only one to worry about is the failure of the soldered joints inside the EBCM. Don't worry about pins/terminals on the connector. As I said before you either re-solder the EBCM yourself or pay a place like ABSFixer $150 to do it. You can only fix a '01-'04 EBCM, the early cars require replacement which means fining one in a junkyard.
If you do decide to try to fix the EBCM yourself, don't screw up....or it might be expensive. That's why I paid $150 to have a professional do mine.
No idea what year you have...no info in your sig. Most common hard failure is a C1214 code, and plenty of reading on this subject if you search the forum.
Lucky, I believe I added my car data to my sig, 2002 Z06, not clear where in the CP I'm supposed to put it.
Also, I have seen that post, thanks Grimlock. As for the repair, that type of work is common for me. When/if I get the codes, I'll be digging in with my Weller station.
