LS1 Harmonic balancer
Old Dec 10, 2011 | 07:41 PM
racingchester's Avatar
racingchester
Default LS1 Harmonic balancer
Flat rate for R & R.
Old Dec 10, 2011 | 07:45 PM
lucky131969's Avatar
lucky131969
Is this a question? Are you looking for a local shop in your area? Hourly rates differ depending on what part of the country you live in, whether you take it to a dealership or specialty shop, etc.
Old Dec 10, 2011 | 07:56 PM
racingchester
Default Harmonic balancer
Live in Phoenix..Not going to a stealership..
Old Dec 10, 2011 | 07:59 PM
lucky131969
good luck
Old Dec 10, 2011 | 08:00 PM
racingchester
I should ask how much time does the flat rate call for.
Old Dec 10, 2011 | 08:45 PM
paladin85's Avatar
paladin85
Avearage rate is is anywhere from 80-130 dollars an hour. Most likely going to get you for at least 3 hours to change it. Rate does go by where you are located in the country but the dealer is going to be the most expensive.
Old Dec 11, 2011 | 10:01 AM
racingchester
Thanks for the reply. Thats about what I thought on the time.
To LS1 Harmonic balancer
