Minor Problem - Need Help with Backup Light Circuit Issue
Old May 9, 2002 | 01:04 AM
JC in XTC5's Avatar
JC in XTC5
Default Minor Problem - Need Help with Backup Light Circuit Issue
I noticed tonight that my backup lights were not working when I'm in reverse, but do when I use my keyless entry (i.e. approach lights). I went under the car and did some troubleshooting on the Backup Lamp Switch on the tranny (MN6). After checking everything out, I traced the immediate problem to the mini-fuse in the passenger footwell fuse box - it feeds the circuit when the ignition is ON and it was blown. I replaced the fuse and immediately blew again when I put the car in reverse.
I have a suspicion that the backup lamp switch on the tranny is bad, but don't see how it could cause a short since the tranny isn't grounded (aluminum). Has anyone had a similar problem? Does the Backup Lamp Switch have some impedance or is it just a contact switch?
:confused:
I'll do some more troubleshooting on the weekend and then likely need to bring it in for a fix, but any help in isolating this is appreciated.
John
Old May 9, 2002 | 11:44 AM
JC in XTC5's Avatar
JC in XTC5
Default Re: Minor Problem - Need Help with Backup Light Circuit Issue (JC in XTC5)
Just did a search an noticed that a failing backup light switch is a common problem. I don't see anyone else getting a blown fuse though, but I have a few ideas to isolate the problem to the switch now.
Old May 9, 2002 | 01:04 PM
ersatz928's Avatar
ersatz928
Aluminum conducts, and the tranny case is grounded thru the torque tube, to the engine block. Maybe the switch internals have connected to the switch metal base, which is screwed into the grounded trqanny case. Are there one or two wires to this switch?? (Probably two is my guess, which supports my failure theory)
Old May 9, 2002 | 06:35 PM
ghost.rider's Avatar
ghost.rider
Default Re: Minor Problem - Need Help with Backup Light Circuit Issue (ersatz928)
The switch on the MN6's for the backup lights is a common problem - had mine fixed a couple of months ago. Maybe part of the fix is a new fuse but I can't tell from the work order.
Old May 10, 2002 | 10:25 AM
JC in XTC5's Avatar
JC in XTC5
2 wires are on the switch. You're probably right on the short being possible through the tranny. Tomorrow I'm going to test the circuit completely with my multimeter to verify before going in for the fix.
To Minor Problem - Need Help with Backup Light Circuit Issue
