Car Surge
Old Dec 17, 2011 | 12:35 PM
slow78z28's Avatar
slow78z28
Default Car Surge
Has anyone else run into the problem of your vehicle idle dropping down to 500 rpm when disengaging the clutch?
I know sounds weird as hell but seems every time I am coming to a stop or slowing down by putting the car in neutral the cars rpm will drop down to 500 momentarily then even out at 900. This has been steadily getting worse it used to be every other time it would do this, now does it every time the clutch is disengaged.
Old Dec 17, 2011 | 03:39 PM
helga203's Avatar
helga203
Had mine tuned . Mine does the opposite of yours. When i come to a light and pull it out of gear my rmps shoot up to 1300 to 1400 then drops down to 600 to 800rpm then up and down for about 15 to 20 secs, but they said that was normal so i suggust to tune, only if you would like it this way go for it.
P.s I'm looking for a new tuner.
pss might b a vac leak
Old Dec 17, 2011 | 08:55 PM
mickey_7106's Avatar
mickey_7106
i had a similar problem in my A4. turned out to be a stripped wire from the MAF plug
Old Dec 17, 2011 | 08:59 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Vacuum leak or need of an Idle Relearn procedure or both. Pull your codes and post them.
To Car Surge
