Intermittent fuel pump issue
Old Dec 17, 2011 | 08:01 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Intermittent fuel pump issue
I have an intermittent fuel pump problem and by intermittent I mean as much as several months between incidents. On the other hand it could happen tomorrow.
Here is the issue. I turn the key on and the fuel pump doesn't kick on. Everything else works fine. All the fuses and relays check out. I have noticed that it will usually happen if I start the car and drive a short distance and then try to start it again within 10-15 minutes. Also I notice that after about 30 minutes the problem seems to go away and the pump will come on no problem. Once the pump comes on it is fine the car has never died while driving. The pump is fairly new (5 months) The old pump was doing the same thing so I am sure it is not the pump.
Is it possible that this is somehow related to an issue with the security system?
Old Dec 17, 2011 | 09:43 PM
helga203's Avatar
helga203
Look up bill curlee i believe he had a similar problem and it ended up being his igntion switch. Contacts in the switch.
Old Dec 17, 2011 | 10:23 PM
lucky131969's Avatar
lucky131969
No.
The good news is, if you have a 30 minute window of no fuel pump operation, you can find the problem!
Here's what I would do(reference link):
1) Fabricate a 12 gauge jumper wire, and have it ready(with you), so you can jump the relay socket at 30 & 87. With the key on, if the fuel pump runs with the jumper wire, you know all the wiring is good from the fuse box to the pump.
2) If the pump runs with the jumper, find out what is missing....12 volts or ground.
http://forums.corvetteforum.com/1579319450-post12.html
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I had the excact same issue a while back. What codes are shown?
1016, 1064, 1096 are indicative of ground problems that will cause your problem if ground G105 located under the block on the driver's side is loose even a little bit. BC steered me there.
Good luck!
Old Dec 18, 2011 | 10:26 AM
pewter99's Avatar
pewter99
I didn't mention this in the OP but between the original issue (when this first occurred) and the current issue I had a new motor built and installed and the problem remains the same which tends to make me think the ground at the block is not the issue.
However...since anything is possible I will make a jumper and have it on hand. I will also check that ground wire.
While we are at it do you suppose I could have an issue on the underside of the fuse box?
Old Dec 18, 2011 | 06:19 PM
Silverbullet00
Last first,,,not likely that there is a fuse box problem affecting only this and no other symptoms. I too used the jumper, my buddies showed me how, and I still keep it in the car. I would still remove, clean and reinstall the G105 ground using a lock washer and a tad of pressure. a tiny bit of blue Lock Tite wouldn't hurt. Since this was done, I have not had the problem come back.
Goood luck!
Old Dec 18, 2011 | 08:23 PM
pewter99's Avatar
pewter99
Goood luck!
Old Dec 18, 2011 | 09:29 PM
lucky131969
I will stick with my original suggestion.........troubleshoot with a meter. Know exactly what is wrong......no guess work required.
Old Dec 18, 2011 | 11:13 PM
Silverbullet00
You are right of course but some of us still don't know our way around the meter thing,,,,just keep teaching,,,many of us are still learning!
Old Dec 19, 2011 | 12:04 PM
pewter99's Avatar
pewter99
taking any all suggestions and will give it a look see and hopefully figure it out.
To Intermittent fuel pump issue
