Broken side mirror
Old May 9, 2002 | 12:28 PM
Paradigm's Avatar
Paradigm
Default Broken side mirror
Driver's side mirror "popped" the nut that retains the spring. Now the swiveling feature has no tension and I've had to tape the mirror"s housing to the stanchion.
Dealer says I need to replace the entire mirror/stanchion assembly. Anybody else have this occur or know of a reasonable fix.
[Modified by Paradigm, 8:30 AM 5/9/2002]
[Modified by Paradigm, 8:32 AM 5/9/2002]
Old May 9, 2002 | 12:33 PM
ddawson's Avatar
ddawson
Default Re: Broken side mirror (Paradigm)
He is correct. Mine cost $350 for the repair.
Some guys placed a screw from the base into the mirror as a cheap fix.
Old May 9, 2002 | 03:20 PM
D. Brawl's Avatar
D. Brawl
Default Re: Broken side mirror (ddawson)
Mine broke like that, too. I just posted on it yesterday. I got a quote for about $240 and I thought that was a little low.
Old May 9, 2002 | 05:35 PM
TeeJay's Avatar
TeeJay
Depending on how important the swivel functionality is to you, drilling through the base of the mirror cowl into the stanchion [thanks for this word!] and running a screw through is very solid and painfully economical. I forgot that I'd stuck mine on with 2X tape for 1-1/2 years before I ran the screw.
Old May 9, 2002 | 05:54 PM
kenc5's Avatar
kenc5
Same thing happened to me. My wife's 98 driver's mirror "flopped" and I took it to the dealer and they fixed it under extended warranty - not the GMPP. Brand new mirror, painted and installed $330, cost me $50.00(deductible). :D
Ken
Old May 9, 2002 | 11:25 PM
Paradigm's Avatar
Paradigm
Default Re: Broken side mirror (kenc5)
Thanks for the replies.
Looks like the screw will be the fix unless I can get a warranty deal.
Old May 10, 2002 | 12:31 AM
BBC5's Avatar
BBC5
Paradigm,
Don't go for the quick fix, there is an inherent flaw in the C5 side mirrors. Make the dealer fix it!
Both of my side mirrors gave up the ghost...
The first was covered under warranty, the other I had to write to a GM exec to get it fixed out of warranty.
Force these guys to fix your mirror!!!
BBC5
Old May 10, 2002 | 12:34 AM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Do a search in achieves and you will see pictures of the screw fix. I used that to fix mine. The mirrors are junk, this topic comes up once or twice per month. :nonod:
Old May 10, 2002 | 01:13 AM
aces's Avatar
aces
Default Re: Broken side mirror (John's vette)
There is also a thread that shows you how to repair it with a hose clamp inside the mirror.
Old May 10, 2002 | 10:11 AM
Lil Red's Avatar
Lil Red
Hey Paradigm,
You've got mail!
I have sent you the document that shows how to fix your mirror problem. If there is anyone else that needs this info., email and I will get it to you as well!
Hope this helps!
Old May 10, 2002 | 02:19 PM
ddawson's Avatar
ddawson
Default Re: Broken side mirror (Lil Red)
Lil Red,
Please send me a copy. ddawson@visa.com
Thanks,
Old May 10, 2002 | 02:39 PM
rgregory's Avatar
rgregory
Someone broke the drivers side mirror on a '97 I owned I took it apart and popped the spring clip back on and then j b welded it to make it stay. I was a real pain to get it back on though, took many attempts. I didn't have the car long after that so I don't know the longevity of the fix.
Old May 10, 2002 | 04:05 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Broken side mirror (rgregory)
Pardigm,
Warranty should cover it if you are still in warranty. GMPP will cover it with no deductible if you aren't in warranty. On my 97 GMPP paid $274 total including the body shop effort for repainting the mirror.
Bill
Old May 10, 2002 | 06:14 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
I jsut had this happen to me about 2 months ago.... same exact thing... no swivel tension at all... it would just spin around... I had to put tacky in between to keep it from moving before I had it fixed.... YES you have to replace it all, it is impossible to get inside the mirror with the leverage you need to fix the spring... so a new one is necessary... they also come un-painted so you have to get them painted... WARRANTY covered mine so I wasnt out anything....you may check on that... I do have an extended one....hope this is helpful :smash:
Old May 27, 2016 | 02:34 PM
Shifty Wizzard's Avatar
Shifty Wizzard
Default Broken Mirror Housing
Originally Posted by Lil Red
Hey Paradigm,
You've got mail!
Hope this helps!
I know this was a LONG time ago, but do you have and can you email me the info (jperl02@wi.rr.com)? Thanks jim
Old Jun 1, 2016 | 10:06 PM
GUSTO14's Avatar
GUSTO14
Jim,
Aaron, (Lil Red) hasn't posted here since 2014, so you might try sending him an email or a PM to try and get a response.
https://www.corvetteforum.com/forums...5-lil-red.html
Good luck... GUSTO
Old Jun 2, 2016 | 07:35 AM
tbrowne's Avatar
tbrowne
Here is one man's fix for the mirror. It may help you.
https://www.corvetteforum.com/forums...de-mirror.html
To Broken side mirror
