1998 coupe ls1 to ls6 intake swap
Old 12-19-2011, 11:51 AM
mig1980
mig1980's Avatar
Default 1998 coupe ls1 to ls6 intake swap
Good day everyone. I will be looking at doing a swap for an ls6 intake when my supercharger goes on. I was curious if there will be anything else I need to purchase to make this swap happen? I live in California so need to make sure SMOG is not affected and no codes are thrown.
Let me know your thoughts.
Old 12-19-2011, 12:05 PM
lucky131969
lucky131969's Avatar
Try a search. This topic has been discussed in detail for the last 10 years.
Old 12-19-2011, 01:28 PM
mig1980
mig1980's Avatar
so i tried a search (which I tried before posting) and found the following things needed:
Coolant Pipe - #12568478 (1 required)
Rear Coolant Plug - #12562788 (2 required)
Would this be it?
Old 12-19-2011, 01:34 PM
lucky131969
Would this be it?
Correct.
Old 12-19-2011, 02:21 PM
mig1980
mig1980's Avatar
Thank you.
Old 12-19-2011, 06:16 PM
ipuig
ipuig's Avatar
St. Jude Donor '09
Not worth the effort of swaping intakes for a FI application in my opinon.
Old 12-19-2011, 08:38 PM
lionelhutz
lionelhutz's Avatar
That's what I was thinking....
Old 12-19-2011, 08:42 PM
lucky131969
....and somehow....it worked out just fine for me.
Old 12-20-2011, 04:54 PM
zavod
zavod's Avatar
You might try looking on Ebay for a kit... I got mine off a engine builder on there for $225 shipped... Took about 2 hrs for the install start to finish! My engine was pretty dirty!
Old 12-20-2011, 05:57 PM
baxsom
baxsom's Avatar
Would this be it?
unnecessary.
Old 12-20-2011, 10:08 PM
lucky131969
Originally Posted by baxsom
unnecessary.
It is for those of us that cringe at the thought of taking a chisel to a new manifold.
Old 12-22-2011, 11:33 AM
baxsom
baxsom's Avatar
but it is for those of us that cringe at altering the cooling system. you dont even have to remove all of the casting ribs. just the ones that interfere.
Old 12-22-2011, 11:42 AM
lucky131969
....you dont even have to remove all of the casting ribs. just the ones that interfere.
I'm well aware of what is damaged to facilitate the use the air bleed tubing.
To each their own........not for me.
Old 12-22-2011, 01:08 PM
lionelhutz
lionelhutz's Avatar
Just by a used one then.
Even better, buy a used one already modified for a LS1.
Old 12-22-2011, 04:23 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Not "needed" with FI but it will help power regardless.
To 1998 coupe ls1 to ls6 intake swap
Quick Reply: 1998 coupe ls1 to ls6 intake swap
