wiper washer button sticking
Old Dec 19, 2011 | 02:05 PM
rlewis02's Avatar
rlewis02
1st Gear
Default wiper washer button sticking
My 02 wiper washer washer button was sticking in the on position and pumping the water bottle empty. After reading several threads on the forum I knew I was going to spend at least a $150. BUT WAIT. I took a small screwdriver and pulled the button out and low and behold one of the plastic retaining pins was bent. With a little heat and a little patience I heated and pulled the plastic pin back straight and snapped the button in and WOW. 10 minutes and no cost!! Be careful there are 2 mini springs under the button that can shoot off into the unknown.
Old Dec 19, 2011 | 08:15 PM
z06fred1's Avatar
z06fred1
Default correction
the two little springs do not shoot off into the unknown, they hit your wife in the face causing her to cuss and you to laugh hysterically. then you cuss because all your wiper fluid is pumping onto your freshly waxed baby. lol, good luck with the wiper stalk.
