My 2000 vert has a steady C1217 code. It comes on as soon as the car moves after clearing. I'm also getting an occasional C1243 code. The car had them (along with other problems) when I bought it. From what I've read, the pre 2001's aren't being fixed. Does anyone have more information on the relay, it's location, and solutions? I'm sure it's causing the ASR lamp and the ABS light to come on along with three messages.
Maybe I have the wrong codes. I'm showing DCT C1217 Pump motor relay contact open , and DTC C1243 BPMV pump motor stalled.
Yeah, you're right. I was a bit tired when I responded to your thread. Been on a large M&A deal the last few weeks and a bit worn out.
If you can find someone with a Tech2 locally you can try the automated bleed procedure to see if that fixes things for you. Sometimes the relays stick.
