C5 AC trouble
Old Dec 21, 2011 | 02:46 AM
ClevelandG's Avatar
ClevelandG
2nd Gear
Default C5 AC trouble
Got something weird going on, my passenger side ac works just fine gets cold, but the driver side stays hot any suggestions?
Old Dec 21, 2011 | 06:44 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
blend door or it's low on freon
Old Dec 21, 2011 | 07:05 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
And post in the C5 section!!
Old Dec 21, 2011 | 07:14 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
moved to C5 Tech....
OP you may wanna check the DIY sticky up top although as already mentioned the blend door is stuck or you are low on freon...my bet is the door. Need to replace the actuator
Old Dec 21, 2011 | 11:52 AM
rebelheart's Avatar
rebelheart
Most commonly,you are simply a bit low on freon.
Old Dec 21, 2011 | 01:28 PM
corvettebob1's Avatar
corvettebob1
Are you now or in the recent past had battery trouble?
If so it's more then likely the blend door, I just went through the same issue on another GM car with auto air.
The battery went dead and I replaced the battery and the AC blew hot air on the drivers side only after the replacement.
I pulled the fuse to reset it and it did nothing, then I removed the positive battery cable for ~5 minutes and it works again!
Old Dec 21, 2011 | 02:39 PM
BigGun's Avatar
BigGun
And if it's the actuator you should be able to pull the code using the dic. It will tell you which side if either is not working properly.
Check this thread. http://forums.corvetteforum.com/c5-t...ese-codes.html
Old Dec 21, 2011 | 02:55 PM
jrose7004's Avatar
jrose7004
That's what mine does.
Old Dec 21, 2011 | 09:36 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Mine was low on freon when that happened, turned out the compressor front seal was leaking it slowly.
Old Dec 23, 2011 | 12:09 PM
ClevelandG's Avatar
ClevelandG
2nd Gear
thanks for the quick response, sorry if I posted to the wrong section, removing power seems to have fixed it. if it happens again I will look at actuator
To C5 AC trouble
