Coolant temp swings ?
Old Dec 22, 2011 | 02:19 PM
had2have-it's Avatar
had2have-it
Default Coolant temp swings ?
All summer long my all stock '01 6spd 40thou mi. had no overheating problems at all. In traffic I would see a 10-15 degree increase but back on the highway it would be 190-195. Now with winters' cooler temps I'm getting overheating in traffic, seems weird to me. I've seen 240+ in traffic and when I get to the highway it will cool off but not as much as it would only a few months earlier. I can smell coolant when I get out of the car but never inside, I have checked the recovery tank and it's at the right level. I've checked the motor, radiator,etc for leaks and can't find any? Recently I have heard a faint squeal on easy acceleration, could the water pump be failing without leaking? Any insight on this would be appreciated, I'm not enjoying the car right now thinking that somethings going wrong with it.
Old Dec 22, 2011 | 02:53 PM
dougbfresh's Avatar
dougbfresh
Maybe you sucked up a bag in the front of the radiator?
Old Dec 23, 2011 | 02:27 AM
03newjersey's Avatar
03newjersey
Default You might need to burp it?
Check this post out...
http://forums.corvetteforum.com/c5-t...ng-issues.html
My stock 03 coupe had a situation last Spring when it would run extremely hot once in a while. Although the coolant tank looked full and there were no leaks my problem was that I had to burp the system 4-5 times and after that I was able to add nearly a gallon of coolant, which solved my problem. Its doesn't cost you anything to try it out and it might be a simple fix. Note: If you do try it then make sure you do it atleast 4-5 times because some people get discouraged when they see no change after the first or second try and give up too early. Good Luck!
Old Dec 23, 2011 | 08:00 AM
Paul 75 L82's Avatar
Paul 75 L82
Take your garden hose and maybe even compressed air and blow out the rad core for dirt. Here's the burping info.
Start w/ a cold engine
Remove rad. cap
Idle for 1 minute
Install cap
Cycle RPM from idle to 3000 until coolant reaches 210F
Shut off engine
Remove cap
Start engine
Idle for 1 minute
Install cap
Shut off engine
Remove cap
Top off
Old Dec 23, 2011 | 09:38 AM
had2have-it
Why would I need to burp the cooling system if it was working in the summer and there is no evidence of coolant loss? thanks
Old Dec 23, 2011 | 09:42 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I wonder if you have a fan motor that has gone out.
Old Dec 23, 2011 | 11:57 AM
had2have-it
Originally Posted by 8VETTE7
Or perhaps a fuse or relay (there are 3 of each in the wiring for the fan system) that has gone out.
Any pics or wiring schematics to help locate the relays and the fuses?
Old Dec 23, 2011 | 12:01 PM
Paul Wood's Avatar
Paul Wood
In addition, it could be that in hotter weather you were running your A/C and that commands both fans to be on thus no over heating. With cooler temps only one fan would be on until you reach the predetermined high limit temp. Burping is your next best step IMO
Old Dec 23, 2011 | 12:13 PM
had2have-it
I thought of that but I also figured the reduced winter air temps would keep the engine fairly cool inspite of not using an AC triggered fan. I can see I'm going to have to check fan function, burp the system, see if the rad is blocked, try to determine if its the water pump, thermostat, aging coolant. I can add that list to the window motor, fuel gauge, TPMS reprogram...list. I love lists. I recently installed a new battery is it either likely or possible that when doing that I could have killed a fan relay or fuses? I also notice a slight squeal on easy acceleration, does that indicate a failing water pump? When I last parked in the driveway, after exiting the car I did smell coolant but haven't seen any leaks and don't remember the fans running to try and knock down the elevated temps? So much work and so little time and $$$...?! The good news is I've got alot of hair so if I gotta pull some out no biggie.
Old Dec 23, 2011 | 03:08 PM
03newjersey
There's a good explanation for your question but there are other forum members more experienced to answer that question. In my opinion you should try the simple, quick, no cost solutions first. As the other members suggested...
Check for radiator obstructions like a bag.
Blow out your radiator from behind with a hose or compressed air.
You can gently brush the stones and debris imbedded in the front of the radiator with a narrow soft bristled brush. You'll be amazed what comes out. Just be gentle.
Check your fuses.
Try these solutions first and post your results. Afterwards if it still runs hot then you can think about troubleshooting thermostats, waterpumps etc...
Good Luck!
Old Dec 23, 2011 | 04:18 PM
had2have-it
Thanks everyone, guess I'll have to stop complaining and do some work. I'll do the easy stuff first, and post the results. Happy Holidays
To Coolant temp swings ?
