help me build my stroker ---PICS--
i think the problem is either major ring blowby,90% chance of that OR major valve seal(s) leaking.10% chance of that i think.
anyways im tearing the motor down to check it out and to possibly just rebuild or motor swap.
whatever i do, i will NOT put it back together with the same configuration.
I WAS THINKING.....
scoggin dicky 408 forged rotating assembly $2,000K + junkyard lq9-4 600$ + rebuild and bottom end assembly ( ???) . I want to go forged bc i have been eyeing a couple of my friends FI set ups and would like to keep that option open in the future. i think that my preformance goals would be shooting for low 5xx maybe ?? not sure if thats realistic or not. I will be swapping old stuff onto new motor even the stud kit
BACK GROUND OF OLD MOTOR::::::
i have 243 TEA stage 2 heads and a ultradyn cam now that i will be replacing with something else ( not sure what yet).The motor i have now was build by Los Angeles Preformance Division and was said to dyno @ 448. head studs but not sure if the bottom end is studded. it also has stock intake, tb but halltech filter kit and full exhasut boltons. meizer water pump( no stat)
whats your thoughts or comments, ??? am i being realistic with prices and hp numbers?
thanks in advance
pics cuz eveybody loves picssss
leaking oil on header tub
You can always drop the compression down a bit with a bigger 72cc head if needed.
You mention oil on the header flanges.
Oil out of the exhaust port shouldn't be on the flanges anyway or you'd have a major exhaust leak that you'd detect.
The oil could be as simple as a valve cover gasket leak.... internally -maybe bad valve stems seals, perhaps they are damaged? Again, you should look into a proper compression/leakdown even if it means renting an air compressor and buying the tool (like $35 for the guage) before you swap what may still be a good engine.
I can also tell you that when I took the heads apart on my '01z with 69k miles the exhaust valve seats were hammered. So.... you have a lot of variables aside from piston rings.
On a side note, compression ratio is a bigger concern when it comes to FI. You can just get forged pistons (and if you KNOW you're keeping the car years and will boost it consider 9.5 or 10:1 ratio) , and reuse the rods, the crank is solid up to 800+ rwhp.
You can rebuild your stock shortblock and keep funds in reserve. If you're going FI you don't need a stroker, the 346 will do just fine.
That's a good recipe.Also, to the OP... if you do a compression test and you get low figures in a cylinder or two... you can take the heads off and check the valves to rule those out. The shade tree mechanic method of checking valves is to turn the assembled head upside down on a bench with the chambers facing up. Fill the chambers with solvent (gasoline/whatever) and see if any of the levels seep through the valve seat over a period of several hours. If it does, you know those valves need attention.
Keep us updated!
oil was seeping though the metal exhaust gaskets from the exhaust port. Not sure why i didnt have a noticeable exhast leak tho...
btw, i did replace the valve cover gaskets with blue felpro gaskets. so i know im not leaking from the valve cover. that was the 1st thing i check tho
i will deff keep everyone up date as i go and have plenty of pic.
You've got dual springs. Once, I had dual springs on an LT1 and had a lot of smoke from the exhaust. It turned out that an inner spring broke and it tore the valve stem seal hence oil in the chamber.
Get a super bright flashlight and spend some time looking at the inner springs/seals.
Just an idea.
dropped the pass side header but never could get the drive side header out. pita. ill get it out tomorrow. i pretty much taking everthing out of the engine bay for a major degrease, scrub, wash. im also going through my wires and tidy everything up while i have a chance. ((long tubes melt sh*t))
anyways, heres a pic of my TEA 243s. i got really lucky that they only sustained a (pepering) from the broken piston remains. ill prob send them off to have them checked and cleaned.
havent decided which way i will pull the engine out yet but im getting there. im working in my little one bay garage, so b4 i pulled it apart i backed my car in just incase i had to pull the motor. good thing i did
The TEA 243's are good - with a 11.00 -11.25 compression ratio and decent cam you will easily make over 500 RWHP with no problem.
However, if you want to build the short block for future FI use, then the compression and cam selection will need to be changed - and 500 RWHP is not going to happen - more like ~ 450 RWHP. But add ~10 lbs of boost and you'll be seeing 700 or more at the tires.
If you want a second quote on the rotating assembly or the machine work- or both - I'd be glad to supply that. ALL of our machine work is done in-house in a our modern and fully equipped machine shop.
