Half shaft removal
Old Dec 23, 2011 | 03:11 PM
brian vette's Avatar
brian vette
Default Half shaft removal
I'm trying to replace my driver side half shaft. I have tried the pd penetrating oil but the shaft will not slide out of the splined bearing. Tap, tap,tap not working. Any ideas? Thanks Brian
Old Dec 23, 2011 | 03:36 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Use a prybar to carefully pop the axle out of the differential. Then with the axle nut loose use a block of wood and a hammer to knock the axle out of the wheel bearing. Sometimes the axles come out easy and other times require a little extra force.
Old Dec 23, 2011 | 04:11 PM
Last C5's Avatar
Last C5
Air chisel with a blunted tool installed works like magic.
Old Dec 23, 2011 | 05:28 PM
Dope's Avatar
Dope
Resident moron
BFH
Dope
Old Dec 23, 2011 | 07:19 PM
brian vette
Default Half shaft
I got it. I took the rotor off and attached a 3 jaw puller to hte hub edges and drove the center bolt on to the top of the axel. Worked like a charm , but man it was in there.
I love this forum. Merry Christmas
Brian
To Half shaft removal
