Help...need quick advice on caliper removal
Old May 9, 2002 | 07:44 PM
chi-ching-99vette's Avatar
chi-ching-99vette
Default Help...need quick advice on caliper removal
Getting ready to paint my calipers. Like every other car out there...I loosened the 2 slide bolts on caliper...they are loose...but will not slide out, now they won't tighten back up. Are these 2 bolts just slide bolts? Do I possibly have to remove the entire assembly from the hub? LOL...I make my living as a mechanic...but I dont want to beat on these pins to get them out.
Old May 9, 2002 | 07:52 PM
NassyVette's Avatar
NassyVette
Default Re: Help...need quick advice on caliper removal (chi-ching-99vette)
Those are slide bolts that the outer bracket slides on to compress the pads. The bolts you want to loosen are bigger ones further to the outside. Use that t take the caliper off and after that you can tighten the slide bolts easily.
Old May 9, 2002 | 07:57 PM
chi-ching-99vette
Default Re: Help...need quick advice on caliper removal (Yellow75)
Thx...Yellow 75
Old May 9, 2002 | 08:26 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
The first time out you'll prbably need a breaker bar - they are freaking tight! :mad
Old May 9, 2002 | 08:33 PM
jofre_69's Avatar
jofre_69
Default Re: Help...need quick advice on caliper removal (Godspeed)
make sure you compress the pistions!!!!!!!!!!
Old May 10, 2002 | 01:44 AM
2001C5's Avatar
2001C5
Cruise-In II Veteran
Default Re: Help...need quick advice on caliper removal (jofre_69)
Or, I think the slide bolts require a 16mm wrench to hold them, while backing out the two smaller bolts you were talking about
Old May 10, 2002 | 08:24 AM
Rx7Rob's Avatar
Rx7Rob
Remember to threadloc (red) the slide bolts when putting them back in (I think the torque is 23 ft lbs).
Old May 10, 2002 | 10:18 AM
Jim 47's Avatar
Jim 47
If you haven't started yet, First compress the brake pads to push the calaper cylinders back into their bores. The take a 15 mm wrench and a put a 16 mm (or 5/8) wrench on the flat surfaces of the slide pin the losten the 15 mm bolts which hold the calaper onto the calaper bracket.
It is NOT necessary to remove the larger bolts, which hold the calaper bracket onto the spindle assembly, in order to remove the calapers. You'll have to remove the flexable brake line in order to take the calaper to a convient place to paint it. Make sure you plug the ends of the brake lines on the chassis to prevent the brake fluid from leaking out. Hope this helps. :cool:
Old May 10, 2002 | 12:16 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Help...need quick advice on caliper removal (Jim 47)
I left them on the car and painted them...
That's the easiest thing to do.... :cheers:
Old May 11, 2002 | 03:06 AM
NassyVette's Avatar
NassyVette
Default Re: Help...need quick advice on caliper removal (PoBoy Racer)
I didn't leave them on. But if I did it over again I probably would. You can get the same results if you leave them on. Just have to mask off really well.
Hope whatever you do turns out good though!
To Help...need quick advice on caliper removal
