C5 exhaust turn downs before axle
Old Dec 28, 2011 | 02:22 AM
nine7vette's Avatar
nine7vette
Default C5 exhaust turn downs before axle
Right now I have TSP headers going into the X pipe with a Borla cat back exhaust. The car is going to be used for drag racing, and I would like to see pictures or if you have any suggestions of the best way to just dump the exhaust with turn downs to avoid heat near the leaf spring. I am trying to eliminate what I can from the car and make a simple exhaust with mufflers and turn downs without using the cat back. Thanks
Old Dec 28, 2011 | 02:51 AM
Lothar34's Avatar
Lothar34
You won't have much room for mufflers like that. You'd probably have to use a couple glasspacks at the rear of the tunnel. You should be able to put a couple turndowns right near teh rear mount point for the midpipes just in front of the transmission.
