Been tracking down some front end noise but having trouble when today i noticed i have no nuts on the bolts that go from the front leaf spring to the lower control arms. Just bolts with thread and a washer and nothing on them. That cant be right can it
You very well have found the problem?
If the bushings are cut off the bottom of the stock adjusters, & the rubber has worn off, there could be metal to metal contact.
Same holds true with after market adjusters, if the rubber pad has worn off & there is metal to metal contact.
Stock GM adjuster on the right with bushing uncut.
