When do I need better injectors?
Old Jan 5, 2012 | 09:26 PM
Lifted07Sierra's Avatar
Lifted07Sierra
Default When do I need better injectors?
At what rwhp do you usually need upgraded injectors?
What are stock in a 2000 ls1 vette and what should I go up to and what brand?
Old Jan 5, 2012 | 10:12 PM
Silnus's Avatar
Silnus
Depends on your duty cycle but most people buy injectors when they do heads/cam swap. You may be able to get away with it with a small cam only job. They would be maxed out.
Old Jan 6, 2012 | 09:42 AM
mitchcole's Avatar
mitchcole
Stock 2000 LS1 are rated at 24# at 3 bar. The LS1 actually runs at 4 bar (atmospheres - 4 x 14.7 psi) so you get 28#. They are made by bosch.
When I upgraded - I had to upsize my injectors (per the tuner). He also said - it's not a problem to overshoot the sizing by a bit. So if you only need 32, you can buy something like a 42 withouth a problem. Waaay oversized has some issues with pooling and spray pattern from what I've heard. I bought 36# injectors (image below) which would actually flow around 42 from what I was told. I'm at 412 rwhp.
I found a set rebuilt - which simply consists of taking it apart and cleaning the basket and shooting a little carb cleaner through them. They were flow tested to within 2%.
They're one of the most reliable parts of the car.
Old Jan 6, 2012 | 10:38 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Here is the math..
HP x BSFC / Number of Injectors x Duty Cycle
example
HP = 350
BSFC = .5 (normally aspirated)
Injectors =8
Duty Cycle = .80 (80%)
350 x .5 = 175
8 x .80 = 6.4
175 / 6.4 = 27.34 lb hr
Old Jan 6, 2012 | 10:45 AM
Lifted07Sierra
Originally Posted by C_Williams@RPM
Here is the math..
example
HP = 350
Injectors =8
350 x .5 = 175
8 x .80 = 6.4
So going in reverse it looks like a 36lb injector will be plenty for me.
I guess if I can find a 36 or 42lb thatll be ok?
Any brands to stay away from? Or ones to try and get?
I have no clue about injectors
Old Jan 6, 2012 | 10:53 AM
0C_Williams@RPM
Former Vendor
Many reputable companies sell injectors including FIC & IDC
Yes, 36 lb hr will be good
FIC LINK
IDC LINK
Old Jan 6, 2012 | 02:21 PM
Lifted07Sierra
FIC LINK
IDC LINK
$400 for injectors? I know Ive seen GM ones for $199 but can't remember how many lbs they were or if they were even for LS1s, not sure if injectors are engine specific though?
Old Jan 6, 2012 | 02:53 PM
0C_Williams@RPM
Former Vendor
Of course the price varies and there are many good choices as well as bad - look for SVO RED TOPs - seen them for 125-150 a set -
Old Jan 6, 2012 | 10:32 PM
mitchcole's Avatar
mitchcole
new injectors are expensive. Mostly because there's 8 of them. You're looking for the high impedance versions. That's why I bought used.
FWIW: My tuner turned me away from the ford SVO injectors. More likely than anything else - he didn't know how to tune them. So a consideration is what your tuner is familiar with - because he's the guy who has to make them work.
Old Jan 7, 2012 | 01:45 AM
feeder82's Avatar
feeder82
My car makes 430rwhp on stock injectors with no duty cycle problems
Old Jan 7, 2012 | 08:14 AM
CTD's Avatar
CTD
I've a set of Red Top SVO's if you are interested. If you are HPT capable I can supply the correct data as well.
These worked nicely with my 346 H/C/I. I have ID 1000's now.
To When do I need better injectors?
