So, I added a cat back exhaust, Blackwing intake and a smooth intake connector (at throttle body) to my 2001 LS1 vert about 200 miles ago Now I get a check engine light. When I clear it, it stays off for 20-30 miles then hits again. Gas cap is tight.
Any ideas?
Car has only 17K miles on it. Just bought it. Cleaned all grounds
Any ideas?
As others have said post the specific DTC. We'd just be guessing without the code...
Many users of the "Blackwing" have reported intermittent lean bank codes. Check the codes on the DIC to confirm why the check engine light is occurring. It also happened to me, but it may have had to do with my 5,200ft altitude.
Did you perform the "idle relearn" procedure? It might help.
Get a small mirror and check the (semi rigid) smooth silicone coupler beneath the throttle body. People buy those things thinking they're an improvement, but I found them to contribute to the same issue you're describing.
The coupler may pucker allowing for an air leak when clamped. It's almost impossible to see w/o the use of a small mirror and flashlight. If that's what you find, use a little lubricant (WINDEX or spit) to lube the ID of the coupler and re-install fully seating the coupler against the throttle body. Rotate the coupler around a bit and confirm no pucker.
I changed out to an SLP coupler which has a little more flex to it.
Yes, I must have cleared it when getting rid of the light. That is, no H codes come up on the DIC when I run the codes. Light has not come in since, but always does in a few miles.
