Disconnecting Tire Senosors..help please.
Old May 10, 2002 | 09:44 PM
goldnarms's Avatar
goldnarms
3rd Gear
Default Disconnecting Tire Senosors..help please.
Greetings All,
I'm currently running non-runflats. Much to my dismay the car is going crazy with warning messages. I get "high tire pressure" for all 4 tires.
How can I disconnect or remove the tire sensors. Thank you :confused:
Old May 10, 2002 | 09:53 PM
lotzahp's Avatar
lotzahp
Default Re: Disconnecting Tire Senosors..help please. (goldnarms)
must visit dealer with Tech2 to un-program TPM option in BCM.
Old May 10, 2002 | 10:04 PM
Corvette Poor's Avatar
Corvette Poor
What cold tire pressure are you running to start with ? I hope it isn't over 30 psi .....
Old May 10, 2002 | 10:07 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
I am running non-runflats and no problems with sensors here. Did the problem start right after you put them on?
Old May 10, 2002 | 10:13 PM
see5's Avatar
see5
Did you reprogram the sensors? Are the wheels in the same positons as before tire change?
Old May 10, 2002 | 10:20 PM
goldnarms's Avatar
goldnarms
3rd Gear
Thank all of you very much for your replies.
As soon as the new tires were put on i started getting the messages. It is very annoying because it cycles through EVERY tire. I haven't checked the actual tire pressures of the current tires. I didn't realize this would effect the reading of the sensor since the tires are not EMT.
If you guys think that will help I'll check.
Old May 10, 2002 | 10:47 PM
aces's Avatar
aces
some tires with steel belts cause problems.
Old May 10, 2002 | 10:59 PM
see5's Avatar
see5
Default Re: Disconnecting Tire Senosors..help please. (aces)
My guess is tha the tires are over inflsted and/or the wheels are crossed from their previous positons and the sensors need to be reprogramed to renew their position on the car.
Old May 11, 2002 | 05:26 AM
goldnarms's Avatar
goldnarms
3rd Gear
Thank's everyone for your replies...i'll heed your suggestions.
To Disconnecting Tire Senosors..help please.
