Differential Drain & Fill Plugs
Old Jan 9, 2012 | 12:24 AM
LIGHTNING's Avatar
LIGHTNING
Default Differential Drain & Fill Plugs
Routine maintenance...
Changed out GM Synthetic Axle fluid to Dexron LS last week.
Only had 11k miles on it...no probs with diff...fluid came out clean.
But I noticed a dark gray glob on the magnetic drain plug.
Anyone else notice this?
Also, no washer (no "axle fill" tag either...came without one from factory) on fill plug. OK to install without one?
Old Jan 9, 2012 | 01:25 PM
don hall's Avatar
don hall
Comprehensive 'how-to' with pics...... no mention of a "dark gray glob" on drain plug, nor a washer:
http://www.toquez06.com/diff.html
Old Jan 9, 2012 | 02:07 PM
BitViper's Avatar
BitViper
"Dark Gray Glob" = Metal
It is after all a magnetic plug..
Old Jan 9, 2012 | 05:10 PM
LIGHTNING's Avatar
LIGHTNING
Never seen it like that before. Trans & oil mag plugs just metal particles...no glob.
Old Jan 9, 2012 | 05:15 PM
lucky131969's Avatar
lucky131969
It's normal. I'm sure if you google something simple like "drain plug, gray paste"........you find plenty of first timer concerns.
Old Jan 9, 2012 | 05:21 PM
LIGHTNING's Avatar
LIGHTNING
Thanks. It does look like the plug on rt.
Old Jan 10, 2012 | 10:47 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Yep, it looks perfectly normal for a 1st time gear oil change at your mileage.
I did a 1st time gear oil change on my Silverado recently, (also with about 10k miles on it) and I saw about the same amount of metal paste attracted to the soft magnet on the inside of the diff. cover.
BTW, you made a good choice for your new gear oil.
To Differential Drain & Fill Plugs
