Air pump
Old Jan 9, 2012 | 07:22 PM
dglad's Avatar
dglad
Default Air pump
Is there a way to check if the air pump is working I changed my skid plate and in the process broke the original air pump where the hose connects. I got a used one but now check engine light comes on and the code is for the air pump should I just by a new one.
Old Jan 9, 2012 | 08:05 PM
dieselbill's Avatar
dieselbill
Try disconnecting the air supply hose going to the manifold and see if it pushes air.
Old Jan 9, 2012 | 08:11 PM
lucky131969's Avatar
lucky131969
did you verify if worked before installing it?
Old Jan 9, 2012 | 09:20 PM
dglad's Avatar
dglad
No I didn't I got it from Marc at vette nuts and just assumed it worked.
Old Jan 9, 2012 | 09:21 PM
lucky131969
ok.
To Air pump
