[PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
Old 01-15-2012, 02:12 PM
  #41
JETninja
JETninja's Avatar
WA Events Coordinator
Very Nice!
Old 01-15-2012, 11:41 PM
  #42
Chaplain
Support Corvetteforum!
Chaplain's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Nice...
Old 01-25-2012, 09:57 AM
  #43
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by Toque
Here are my actual results.
Very cool! Excellent results and the true gains are felt through the entire power band!
Old 01-25-2012, 10:25 AM
  #44
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Thanks ! Yea it for sure feels stronger now. It was a fun install, and I learned something new. Still looks stock-ish under the hood too which is what I was hoping for.
Toque
Old 02-04-2012, 10:42 PM
  #45
SR-71
SR-71's Avatar
Nice #'s Mark
Old 02-05-2012, 02:55 AM
  #46
Toque
Toque's Avatar
Originally Posted by SR-71
Nice #'s Mark
Thanks ! Was out tonight scuffing some rubber off my rear tires...
Toque
Old 03-01-2012, 07:36 AM
  #47
dustysZ
dustysZ's Avatar
What is the reason for running the vent line from the valve cover to the coupler?
Old 03-01-2012, 08:22 AM
  #48
Toque
Toque's Avatar
My understanding is that the valve cover needs to have a place to vent if it becomes over pressure. The stock setup has a tube running to the LS1/LS6 Throttle body. The LS2 Throttle bodies do not have the plug in for the exhaust line. The LS2 cars have a line going to the coupler in front of the throttle body. I needed to connect the exhaust hose to a place that the valve cover could vent. Some people cap off the valve cover exhaust line, and install a small filter on the oil cap cover. Not sure if its legal though, and heard the engine bay will get a little "oily" over time.
See this picture below. It shows the stock exhaust line and what I was planning to do with the new line.
Hope this makes sense.
Toque
Old 03-01-2012, 09:13 AM
  #49
dustysZ
dustysZ's Avatar
Thanx. So I'm guessing I can go either route. Small filter. (Which would go where? On tube coming out of valve cover or in place of oil filler cap and cap of vent line in valve cover) or the line to the coupler.
Old 03-01-2012, 09:21 AM
  #50
Toque
Toque's Avatar
I have seen some attach a air filter to there oil filler cap, and plug/cap the line in the valve cover. Some run a line from the valve cover to a small air filter that loosely fits under the red valve covers.
If I were you, I would talk to some people that have done this filter idea. I don't want to give you any bad advice because I went a different route. I don't want to make it seem that I know a lot about the filter idea.
Toque
Old 03-01-2012, 09:33 AM
  #51
dustysZ
dustysZ's Avatar
Gotcha. Maybe somebody will throw there thoughts in here.
Old 04-08-2012, 10:23 PM
  #52
Bumble Boogie
Bumble Boogie's Avatar
Location: River City USA, East of the Mississippi Peoples Republic of Illinois
Default Fast 92 Manifold install.
I loved your article. I hope you don't mind but I printed all thisrty pages of your post for my tech scrap book. Thanks for taking the time to share your experience with our forum.
Old 04-08-2012, 10:42 PM
  #53
Toque
Toque's Avatar
Your very welcome. I just hope it helps you out !
Toque
Old 04-08-2012, 11:02 PM
  #54
VetteNoob
VetteNoob's Avatar
Not sure if you still need this info, but this is how I vented mine. Mine actually pulls air into the valve cover.
Old 04-09-2012, 11:10 AM
  #55
feeder82
feeder82's Avatar
Ive been looking for those small filters where did you get yours?
Old 04-09-2012, 10:19 PM
  #56
VetteNoob
VetteNoob's Avatar
Autozone. It was $5.
Old 07-03-2012, 08:27 AM
  #57
Toque
Toque's Avatar
TTT since the FAST 92 was re-released from Fast....
Toque
To [PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
Old 03-21-2013, 01:49 PM
  #58
FourG63 97GST
FourG63 97GST's Avatar
I'm about to undergo this, just to verify. You can reuse the stock manifold to head bolts?
Old 03-21-2013, 08:15 PM
  #59
Toque
Toque's Avatar
Yea that's what I did. I found that the stock bolts were slightly longer and went into the head just a little more. And I also verified that the holes in the head allowed for the length of the stock bolts poking out the bottom of the new Fast manifold.
Toque
Old 03-24-2013, 10:08 AM
  #60
b_rad!
b_rad!'s Avatar
I will be installing a released black FAST and LS2 TB in a few weeks and was wondering if you used your old air coupler or needed a larger one to accommodate the move from the 78mm LS6 to the 90mm LS2 TB. Great write up! I will definitely be referring to it.
Quick Reply: [PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
