Got an auto trans? Watch out for this gremlin...
Old 01-06-2013, 12:24 PM
  #41
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by jdkskyking
Broke mine in my attempt to remove boot for cleaning. I've attempted a repair on the Red indicator. Also found a LED bulb at autozone. I'll post pictures soon.
Would love to see what you come up with for a repair...others have tried and failed...that little bugger is a challenge to say the least...
Old 01-06-2013, 12:44 PM
  #42
jdkskyking
Support Corvetteforum!
jdkskyking's Avatar
Default I'm in the process of finishing the repair.
Epoxied a support that I fabricated.
James2000 (01-31-2016)
Old 01-06-2013, 12:50 PM
  #43
jdkskyking
jdkskyking's Avatar
I first glued the broken pieces back together with gel based "Super Glue".
I drilled small holes in each piece to pin the two parts together after gluing with epoxy.
Old 01-06-2013, 01:52 PM
  #44
jdkskyking
jdkskyking's Avatar
Old 01-06-2013, 01:55 PM
  #45
jdkskyking
jdkskyking's Avatar
Default Ready to test my work.
Nicked the tab with my Dremel. I may try to fill it with a dab of epoxy.
Old 01-06-2013, 01:59 PM
  #46
jdkskyking
jdkskyking's Avatar
Default C5 Shifter Boot
Stretches over its mount. Removing the boot from the mount may be the answer to removal and NOT breaking off the red indicator tab.
Old 01-06-2013, 03:27 PM
  #47
Aerovette
Aerovette's Avatar
It doesn't seem to be of much concern considering the thread I started after reading yours.
http://forums.corvetteforum.com/c5-g...post1582751549
(thanks for the pic)
Old 01-06-2013, 03:35 PM
  #48
jdkskyking
jdkskyking's Avatar
I've got to sand down the channel the indicator rides on before I put everything together. Adding the brace and epoxy increases the thickness on those areas. I used 1/64th metal to fabricate the fix.
Old 01-06-2013, 05:01 PM
  #49
$$$frumnuttin'
that bugger has to slide freely in there once all is put back together...very tight tolerances....nice pics and a clever approach...maybe you can get this into the DIY vault pewter99 manages...talk to him.
Old 01-07-2013, 01:21 AM
  #50
jdkskyking
jdkskyking's Avatar
Old 01-07-2013, 01:23 AM
  #51
jdkskyking
jdkskyking's Avatar
Old 01-07-2013, 01:26 AM
  #52
jdkskyking
jdkskyking's Avatar
Old 01-07-2013, 01:29 AM
  #53
jdkskyking
jdkskyking's Avatar
My daughter helped me reassemble the console. She did a great job I'm very proud of her.
Old 01-07-2013, 01:34 AM
  #54
jdkskyking
jdkskyking's Avatar
Default Completed by Brantly
Old 01-09-2013, 06:53 PM
  #55
David Shiel
David Shiel's Avatar
Default Cannot get bulb out and sfraid
I will break the socket. Any ideas?
Old 01-17-2013, 09:54 AM
  #56
David Shiel
Default Help! Bulb won't come out
I saw all the ways to get a grip on it, but............
when I pull hard on the bulb, it looks like the socket it is in deforms. Is that possible? Could I break the socket and be SOL? Or can I pull on it as firmly as required to pull the bulb?
Quit laughing !! Every time I set out to fix something not broke, I break it !!!
Just FYI, the red piece looks just fine on mine, but then only 18K.
No need to disassemble console. Had the bulb exposed in a few minutes by using the suggested small screw driver and proceding carefully. Great input .
Old 01-17-2013, 02:09 PM
  #57
flaagan
CF "Young" Senior Member
flaagan's Avatar
St. Jude Donor '12
So a while ago now I decided to take a look at my shifter to see what the story was, and it was just as cooked as something's was.
What I ended up doing was carefully disassembling the plastics (including the red tab) and grinding down the whole shifter backlight piece so that the just the top curved section was still there.
Then I took a 6" led strip I had laying around from another project and epoxied the thing (like crazy) to the back of the shifter strip, lining up the lights as best I could with the gear indicators.
Since the stock light housing was cooked to the point of disintigration, I snipped the wires and proceeded to wire in the seperate wiring hareness (two wires w/ connector) for the LED strip. This was probably the hardest part of the whole job due to space limitations within the shifter area.
The results, however, were well worth the effort. The entire shifter is incredibly bright now, such that you can clearly see the backlighting even during the day. It's like it should've been.
Sorry I don't have any photos of the work, it was very hands-on so I didn't have a free hand to take photos. If anyone's interested in doing this, I can photoshop up some reference stuff for you.
CorvetteBrent (09-05-2018)
To Got an auto trans? Watch out for this gremlin...
Old 01-17-2013, 05:16 PM
  #58
$$$frumnuttin'
Brilliant! Would love to see a pic of the prndl23 all lit up evenly, that's the one thing I don't like about just switching bulbs...uneven/dim at the ends.
Old 01-17-2013, 05:28 PM
  #59
flaagan
flaagan's Avatar
St. Jude Donor '12
Will do. Just took a couple of shots of it during the daytime, I'll get a couple night time shots this evening and post them up.
That was the other comment I was going to make regarding this little upgrade - before I put the LED's on the back of it, I didn't even realize the back light came whenever the car's on or the doors are opened, I thought it only came on when the headlights were on.
Old 01-18-2013, 12:56 AM
  #60
WilliamCall
WilliamCall's Avatar
Originally Posted by tbrowne
After reading this thread, I pried the PRNDL cover off in order to replace the 194 bulb with an LED. To my surprise - it came of easily and exposed the bulb. However, I could not get a good enough grip on the bulb to remove it from the socket. The bulb would move from side to side but wouldn't come loose. I tried pliers with the jaws taped, wrapped the bulb with rubber - nothing worked and I was afraid of breaking the bulb's glass envelope. I finally tried a piece of narrow, foam weather strip with adhesive on one side. I wrapped the bulb with the adhesive side against the glass envelope and got enough of a grip to pull the bulb. I hope this helps someone else remove the bulb without breaking the glass.
It's very easy to break those bulbs or the bulbs in the sun visor vanity mirrors. What works for me is heat shrink tubing. I place aluminum foil around the bulb (my heat shield protection), slide the heat shrink tubing over the bulb and heat it up with a heat gun. It's important to have plenty of aluminum foil for the surrounding area (so as to not scorch or melt any plastic parts. When the tubing has cooled down, just give it a strong pull and the bulb pops right out.
Quick Reply: Got an auto trans? Watch out for this gremlin...
