engine randomly cutting out and stalling
Old Jan 11, 2012 | 12:32 PM
toomanymodz's Avatar
toomanymodz
Default engine randomly cutting out and stalling
My 1997 vette recently started 'bucking' while I was driving around 60 mph, and when I came to a red light the engine stalled out. This has happened two or three times now. One time a message came on the dash telliing me to remove the key for 10 seconds...
The dealer recently changed out the column lock under a recall. Since I'm a very recent owner of this car, I cannot say if it ever malfunctioned before the dealer did the service or not, but it never misbehaved during the time that I owned it.
I have a hunch that it's the anti-theft. any ideas or suggestions? Can I disable it by reflashing via HP-Tuners?
Old Jan 11, 2012 | 12:39 PM
cdkcorvette7's Avatar
cdkcorvette7
Pull your DTC's and post them. If it is in fact an issue with your column lock mechanism the dealer recall is worthless. Even if the dealer recall hasn't failed yet it probably will. The common solution is to purchase a CLB like the one offered by Corvettes of Houston or make your own (DIY available on this forum) and then have the fuel safety shutoff reprogrammed from 2mph to a very high number (using tuning software like HP tuners).
Pull and post your DTC's per the instructions below:
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Jan 11, 2012 | 01:04 PM
toomanymodz
I was able to pull the following. Lots of codes which surprises me. The battery was recently replaced too.
P0102H
C1255H
B0432H
B0502H
B0503H
B0507H
B0508H
B2593H
U1255H
U1016H
U1096H
B2282H
B2284H
C2120HC
B2253H
B2283H
B2285H
U1064H
Old Jan 11, 2012 | 02:17 PM
sunchaser73's Avatar
sunchaser73
Quite a few of those codes are most likely related to changing the battery. Clear them and post what comes back during your next drive...those are the ones to be concerned with.
Old Jan 11, 2012 | 04:12 PM
toomanymodz
Ok will do. I noticed that one of the codes was for the MAF. I'll monitor the Hz while driving and report back with any new codes.
To engine randomly cutting out and stalling
