backspace offset for 19-20" wheel combo for c5?
The wheel width is only important to mount this wide of tire i want, so I would assume a 9" front and 10-11 inch rear. Has anyone put 19-20" wheels on a c5 if so it would be great to know the offsets you used. and pictures are always a plus. Thanks.
Worse case I will go with 19" front and rear, but would like the staggered look
http://www.ebay.com/itm/19-20-Black-...ht_1419wt_1401
Here are the factory offsets for the C5. I suggest you use this info and the offset calculator (link below) to determine what will work on your car:
Backspace/offset dimensions are as follows:
C5 (coupe/vert):
Front 17x8.5", 58mm offset = 7.03" backspace
Rear 18x9.5" 65mm offset = 7.81" backspace
C5 Z06:
Front 17x9.5", 54mm offset = 7.38" backspace
Rear 18x10.5", 58mm offset = 8.03" backspace
http://www.1010tires.com/wheeloffsetcalculator.asp
What will fit is a combination of the wheel width and the wheel offset. The calculator takes both into account.
Thanks for that info man, i was sure the 12" wide wheel was to wide, and I dont really need it that wide but its all they offer in this type of wheel
