Need advice on rotors and pads
Old May 11, 2002 | 03:02 PM
Richin Chicago's Avatar
Richin Chicago
Default Need advice on rotors and pads
After quite a few sseesions at Gingerman my stock rotors are ready to be replaced. (They have been turned twice) I am quite happy with the OEM rotors and would like to replace them with equivalent (cost) rotors. Can anybody suggest a good source for OEM or comparable? I found these on the Forum:
http://store.yahoo.com/corvetteforum/ppwerrotseps.html
Any better values out there?
I don't want to use cross drilled.
Also I find that the Hawk "street" pads are cutting grooves in my rotors even though the pads are still quite thick and I followed Hawk's break in proceedure. Has anybody else experienced this?
Thanks,
Old May 11, 2002 | 04:24 PM
vette0202's Avatar
vette0202
Cruise-In I Veteran
Default Re: Need advice on rotors and pads (Richin Chicago)
Did you check my "DBA Post". I am getting a group purhase from Precision Brake comopany for some DBA rotors. They have cross drilled rotors called Longlife Gold and just slotted rotors called Longlife Slotted.
Old May 11, 2002 | 04:45 PM
Richin Chicago
Default Re: Need advice on rotors and pads (vette9898)
Are you doing both slotted and cross drilled or can you mix?
Old May 11, 2002 | 04:58 PM
vette0202's Avatar
vette0202
Cruise-In I Veteran
I am pretty sure you can get either one you want. I will call them on Monday. They sell rotors in pairs(Either front or rear). There Longlife Gold are both slotted and cross drilled. There Longlife slotted are just slotted. Check out their web page... http://www.dba.com.au/home.htm
Old May 11, 2002 | 05:10 PM
Richin Chicago
I appreciate it!!!
Old May 11, 2002 | 08:14 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
If you are going to track your car a lot, just stick with the OEM rotors. As soon as you go to cross-drilled rotors on our cars, you are asking for cracking problems when you are roadracing. I have seen the Eradispeeds put up with a huge amount of abuse on the track, but they are quite costly if they are a maintenance item.
I just run OEM rotors with some PFC pads (01s on front and 99s on rear).
The stock C5 calipers and rotors are VERY good and just need a few simple upgrades to help disapate the heat.
Old May 11, 2002 | 08:30 PM
mnasrallah's Avatar
mnasrallah
check out this site for rotors. http://www.discbrakesrus.com/make/ch...t/corvette.htm
scroll down to the middle of the page for the rotor section
Old May 11, 2002 | 10:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Need advice on rotors and pads (mnasrallah)
Ken Fitchner and GMPartsDirect both sell the stock rotors at good prices, sorry I don't have the URLs in this computer.
Old May 12, 2002 | 01:00 PM
MelloYellow's Avatar
MelloYellow
Default Re: Need advice on rotors and pads (Gearhead Jim)
Trying out PFC Z's right now. Anyone have experience with them?
I hated Hawk Streets.
Old May 12, 2002 | 01:05 PM
Richin Chicago
Default Re: Need advice on rotors and pads (MelloYellow)
I'm also not happy with Hawk Street Pads. They are tearing up the rotors. Glazing???
Where can you buy PFC pads?
Old May 12, 2002 | 01:38 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
IF you are not running on a Road Course, any rotor will last a long time. It all comes down to what look you want to have.
vetterdstr :cheers:
To Need advice on rotors and pads
