Body Code 2127
Old Jan 21, 2012 | 04:14 PM
BRISLS1's Avatar
BRISLS1
St. Jude Donor '11, '14,’19
Default Body Code 2127
I am getting only this code, and the security light.
Both of my keys are a but worn. Not sure if this is related to the key or the ignition hardware.
Anybody get this code? Can it be tuned out using HP Tuners?
Old Jan 21, 2012 | 04:23 PM
lucky131969's Avatar
lucky131969
No, the code cannot be tuned out. It is a BCM code, not a PCM code.
Helps if you post the correct code. I assume you meant a "B2721" .....not ......"B2127". If you do a search for B2721, you'll find plenty of reading, troubleshooting, etc.
Old Jan 22, 2012 | 12:09 AM
BRISLS1's Avatar
BRISLS1
Sorry for the sloppy post. It's just cold and rainy here, and I was in a hurry to get out of the car after reading that code.
I just wondered about the tuning, because I got the column lock tuned out.
I'll search more. Thanks.
Old Jan 22, 2012 | 12:19 AM
lucky131969
You can't "tune out" the column lock. What can be done is adjusting the 2 mph fuel shutoff...that is a function of the PCM....not BCM.
To Body Code 2127
