clutch fluid change
Old Jan 22, 2012 | 09:10 AM
red89c4's Avatar
red89c4
Default clutch fluid change
i will probably be in trouble for starting a new thread on a covered subject but here goes.
i have a 03 with 6 spd. i have noticed all of the treads about slave cyl and clutch pedal problems. no problems at this time just want to protect what i have. how do i change the fluid in the clutch master with out introducing air into the lines and requiring a bleed of the assist cyl. if i completely drain/remove all fluid from the master and do not depress the pedal will air get into the system?
Old Jan 22, 2012 | 09:15 AM
dougbfresh's Avatar
dougbfresh
Ranger method, LOOK IT UP!
Old Jan 22, 2012 | 09:48 AM
baxsom's Avatar
baxsom
use a turkey baster and suck out some fluid, replace with fresh, pump pedal a few times, repeat until the fluid is clear in the reservoir.
Old Jan 22, 2012 | 09:59 AM
bumble-z's Avatar
bumble-z
The answer to your question is..NO
Your question was " IF I completely drain/remove all fluid from the master & do not depress the pedal, will I get air into the system?"
Good luck & keep that hydraulic reservoir, m/cylinder clean.
Old Jan 22, 2012 | 10:11 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Good luck & keep that m/cylinder clean
I agree; I did the turkey baster method but my trans broke 3 weeks ago, lost 3rd gear synchros and blocker keys. I now have a stage 4 trans and added the Tick remote bleeder for this reason.
Old Jan 22, 2012 | 09:31 PM
red89c4's Avatar
red89c4
this forum is great after i was informed of the name of the method i searched and found the below link
http://www.rangeracceleration.com/Clutch_Care.html
great video
my fluid is as black as coal, i will be flushing and changing asap. thanks guys!!!
should i do the same for the brake fluid?
Old Jan 22, 2012 | 09:35 PM
bumble-z's Avatar
bumble-z
great video
Yes.
Being the brake resevore is so much larger than the clutch resevore, you might want to get one of those larger rubber squeeze type bulbs with spout. Mainly used to pull /add, acid to & from the battery.
Be real carefull that the hydraulic/brake fluid doesn't get splattered on painted surface.
Good luck.
Old Jan 22, 2012 | 09:51 PM
red89c4's Avatar
red89c4
thank you bumble-z
Old Jan 22, 2012 | 10:16 PM
ALLEGRO's Avatar
ALLEGRO
Old Jan 23, 2012 | 11:05 AM
AJ Powers's Avatar
AJ Powers
WalMart has a syringe with a small hose already attached to it that I find works much better than a turkey baster.
To clutch fluid change
