Interior Lights-new owner-need help
Old Jan 23, 2012 | 12:32 AM
Iwant1c5z's Avatar
Iwant1c5z
Default Interior Lights-new owner-need help
Hey gents I'm a new owner of a c5z just bought it saturday morning. Few issues on the interior is the lighting... I have used the search button but just not having luck or I'm just special and can't find the right threads. But the interior temp display is damn near out. Can only see it at night and just barely even then, also on the dash the #3 trip and #4 options buttons are out. Any threads on how to replace these bulbs? And or swapping out to leds (if there not already) they are just driving me crazy already! Thanks for the help and mybad in advance if I'm beating a dead horse
Old Jan 23, 2012 | 01:04 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Congratulations.Common problem. Semi easy fix.
Old Jan 23, 2012 | 10:21 AM
Jewjenk's Avatar
Jewjenk
Did you check the dimmer switch to make sure it was turned all the way up?
Old Jan 23, 2012 | 10:23 AM
Turbopower87's Avatar
Turbopower87
I just fixed mine this weekend using that thread as a reference. Much easier than I had anticipated. Good luck
Old Jan 23, 2012 | 08:15 PM
Iwant1c5z's Avatar
Iwant1c5z
Awesome thanks gents! That looks much easier than I had anticipated and yes I have checked the dimmer switch. I will get in there and start soldering those puppies back to health. So this would also effect the #3 and #4 button lights as well? Because these are totally out even at night. (I assume that solder has just lost all connectivity for those 2?)
To Interior Lights-new owner-need help
