I've noticed for a while that the MPH light on the speedo dims and brightens for no apparent reason. This is not huge by any means, but it is just within my peripheral vision and I notice it. At first I thought it was a sign of alternator regulation, but the voltmeter needle doesn't budge. Has anyone noticed this or should I just chalk up the phenomenon as age-induced flashbacks?
There is a photo sensor above the number 1 button on the dashboard. If you put your finger over it in sunny conditions, you will see the MPH fade in brightness. Remove your finger and it will become bright again. GM's attempt at reducing glare at night. :cheers:
