Tapping sound in OD solved
http://forums.corvetteforum.com/zerothread?id=279473
This morning I was under the car tidying up the clamps on my FLP's and decided to see if I could locate where the tapping noise was coming from. As I shook the exhaust pipes, I noticed a sound very similar to the tapping sound and discovered that the springs attached to the x-pipe (h-pipe for you stockers) had almost no tension on them and rattled when I shook the exhaust. One of them was tapping against the torque-tube cast housing, thus creating the "metal against the cast housing" sound I had described earlier. I used a wire tie to compress the spring, creating tension on the spring against its attachment points and moving it away from the housing. The other spring was fine so I left it alone. Afterward, I took it for a test drive and, viola', no more tapping. :cheers: :yesnod:
For those of you MN6er's experiencing this, don't let the dealer pull your drive train out looking for the problem before you check this! :nono: I think this occurs in OD gears because 1) there is no torque load on the exhaust during steady-state cruising, allowing the springs to dangle freely if they are not in tension, 2) there is less noise in the cabin while in OD which makes it possible to hear this sound and 3) the wind under the car blows the loose spring around causing it to tap randomly against the housing.
Remember, this was happening on my car before I changed my exhaust so it wasn't a function of different geometry due to new components.
Here's a picture of where the springs are located. The left of the picture is the front of the car.
Hope this helps someone with a very annoying problem. :seeya
[Modified by Patches, 4:59 PM 5/12/2002]
