2 weeks without headlights
Old Jan 28, 2012 | 06:55 PM
2001C5Corvette4Sale's Avatar
2001C5Corvette4Sale
Default 2 weeks without headlights
My low-beams & high-beams recently went out and I haven't been able to get them back on. Here is what I've done:
1) Checked fuses
2) Checked resistance between contacts on headlight-switch/blinker-arm. I rotated the white wheel through all the positions. 0ohms at all contacts.
3) Checked resistance through wiring on headlight-switch/blinker-arm
4) Removed aftermarket HID headlights and ballast
5) Replaced low-beams with Sylvania 9006s
6) Checked voltage on connectors going to low-beams and high-beams (battery voltage here)
Still no lights!! My brights will come on when I pull the headlight-switch/blinker-arm towards me (flash to pass), but that is all. Is there anything else the previous owner would have done when installing the HIDs?
Does anyone have the wiring diagram or what I should check next?
Old Jan 28, 2012 | 07:08 PM
1986coupe's Avatar
1986coupe
Did you cover the sensor on the dash while testing it? I remember that is one thing that I did when testing mine but that was a while ago.
Old Jan 29, 2012 | 01:26 PM
mitchcole's Avatar
mitchcole
http://forums.corvetteforum.com/c5-t...-a-how-to.html
best price is amazon. lookup: ACDelco D1512G
You can also bend the electrical contacts in the original switch to restore their "springy" capability. For me that lasted 6 months. hence the new switch.
To 2 weeks without headlights
