torque tube couplers
Old Jan 31, 2012 | 09:50 AM
mrbumms's Avatar
mrbumms
Cruising
Default torque tube couplers
Hi everyone, this is my first post.
i'm planning on rebuilding my torque tube when i change my clutch, my question is this, are the couplers from corvette central the ones made in germany or are they made in china???
Also, should i change the flywheel and pressure plate bolts or can you reuse the old ones?
Thanks in advance.
Old Jan 31, 2012 | 11:59 AM
cdkcorvette7's Avatar
cdkcorvette7
Thanks in advance.
I don't know about the ones from Corvette Central but I'm pretty sure the German ones are BMW parts.
I'd recommend getting new bolts. I used ARP bolts when I replaced mine...
Old Jan 31, 2012 | 12:17 PM
SaberD's Avatar
SaberD
The fw bolts are torque to yeild. you could probably re-use the pp bolts, but it is not recommended. also replace all the coupler bolts with new ones.
I would only buy the couplers from someone who advertised them as the german ones. there is another option from RPM transmissions that is better than the german ones, but more expensive.
Old Feb 2, 2012 | 11:41 AM
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
Our 585113 couplers are sourced in Germany. The billet/poly couplers we have (585091) are sourced from Prothane, and have a 6061 T6 billet aluminum carrier wrapped around specially formulated polyurethane. This eliminates breakage while dampening the NVH commonly found on solid aftermarket units.
Old Feb 2, 2012 | 02:20 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I ended up buying GM. I made a purchase from another supporting vendor here for "German made" couplers and they fell apart within 1 year causing nasty driveline vibration.
Old Feb 2, 2012 | 04:33 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I have big power and bought the expensive but very good
couplers from RPM as well. Price $375 but worth it on big
power.
To torque tube couplers
