Clutch Adjustment Possible?
Old Jan 31, 2012 | 11:31 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Default Clutch Adjustment Possible?
I'm usually one who tries my best to answer questions and this time I have one to ask. My super high mileage '99, was recently upgraded to an LS7 clutch setup, new slave, pilot and bled by a dealer. Yes, I used my own advice to use the search function and nothing really points out to this issue for anyone else.
Issue: Clutch pedal has about %50 free travel before it does anything. The clutch itself engages about an inch up off the floor. I suspect the clutch master cylinder but without replacing it, is there any other way to find out? The manual states there is a way to adjust the clutch via the inspection port although I'm thinking its only a manual way of releasing the pressure plate so that it auto adjusts or whatever. Like I said, the first %50 of the pedal going down has very little resistance but not lose. Its certainly not pushing against the clutch plates during this initial travel and yes, I took it had had the system carefully bled to insure there was no trapped air following the replacement.
I don't wish to just throw money at it. Thoughts?
Old Jan 31, 2012 | 12:10 PM
SaberD's Avatar
SaberD
This is a very common problem with LS7 clutches. That is why most of the time when you buy an LS7 clutch, you buy an adjustable master cyllinder. this will allow you to adjust the grab point. Tick makes a good adjustable master cylinder. hope this helps!
Old Jan 31, 2012 | 01:02 PM
dgrant3830's Avatar
dgrant3830
Thanks, I'll research a little and see what they go for.
Old Feb 1, 2012 | 03:31 PM
bumble-z's Avatar
bumble-z
The Tick is right at $300. Maybe alittle more or a little less.
Labor to have the Tick installed, I would imagine to be around $100.
I did my own install & I like the results of the Tick adjustable,clutch master cylinder.
Good luck.
Old Feb 1, 2012 | 03:39 PM
dgrant3830's Avatar
dgrant3830
Yeah, the 1st price I saw for it was over $300. I can live with mine the way it is, as long as its not preparing to fail on me.
To Clutch Adjustment Possible?
