I give up....
Old Feb 2, 2012 | 12:12 PM
  #41
cwis9992's Avatar
cwis9992
Originally Posted by m6 c5
He best start working out, but a crank starter would probably work better
And back on topic, did you ever get it to idle correctly? Are you sure the hoses are sealing 100%? I had the same leak on mine and it would only want to stall out on a rare occasion when it was cold out, once I fixed it it ran like yours is/was until I did an idle relearn. The idle relearn I did was given by Bill Curlee if Im not mistaken but it was different than the one he posted here. Im sure he can verify if there is more than one way to do one however.
he could probably do with the workout. nothing like the incentive of being able to drive your car to make you work your *** of
and im gonna try and find the hoses for it bc im about 99% they are but...
  #42
m6 c5's Avatar
m6 c5
Originally Posted by cwis9992
you said drive at varying rpm for the relearn procedure. are you talking like set my cruise at 65 in 2nd gear for so many miles, then different rpm, or are we talking about just running through the gears or....??
im about to have to make about a 45ish mile drive so perfect
I think its talking about something similar to city driving.
Old Feb 2, 2012 | 12:40 PM
  #43
cwis9992's Avatar
cwis9992
and my drive as all highway so i gotta keep myself entertained and vary it on my own...
Old Feb 2, 2012 | 01:00 PM
  #44
cwis9992's Avatar
cwis9992
wellp.. im gonna try the idle relearn now and go on that drive. i'll let ya'll know what happens when i get back. thanks again for all the help!
Old Feb 2, 2012 | 04:49 PM
  #45
cwis9992's Avatar
cwis9992
Default Thanks!!
ok so i did the relearn procedure thingee. its not hesitating or stumbling or bouncing or any of that crap like it was before, it's still ideling lower than it used to, but that could have been a product of this being a building issue. what does your ls1 idle at when its warm???
Old Feb 2, 2012 | 05:27 PM
  #46
chaase's Avatar
chaase
St. Jude Donor '12
A stock, warm, LS1 idle is around 500rpm. It should be low, V8's don't need a lot of RPM to idle unless they have a lot of cam.
Old Feb 2, 2012 | 07:46 PM
  #47
m6 c5's Avatar
m6 c5
According to hp tuners mine is set at 800 and thats from the factory...
Old Feb 2, 2012 | 08:29 PM
  #48
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
My 2004 Z06 idle was 650 rpm stock.
Toque
Old Feb 2, 2012 | 09:02 PM
  #49
m6 c5's Avatar
m6 c5
Toque
Hmm I dont think Im looking in the wrong place and as far as I can tell it had never been tuned before...
Old Feb 2, 2012 | 10:10 PM
  #50
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Glad the relearn worked, I had a feeling that's what it needed. I am sitting at 850 warm. What is "lower than it used to" exactly....
Old Feb 3, 2012 | 09:14 AM
  #51
cwis9992's Avatar
cwis9992
yesterday it was sitting around 600. now it's back up to where it always set before this started around 850
Old Feb 3, 2012 | 09:28 AM
  #52
chaase's Avatar
chaase
St. Jude Donor '12
800 may be okay, depending on what you are doing when measuring. If the car is in park, that might be normal. I thought my A4 would idle between 500 and 600rpm but that may have been in drive with the breaks on.
Old Feb 3, 2012 | 12:38 PM
  #53
cwis9992's Avatar
cwis9992
that sounds reasonable. mines a manual so that idle is in neutral sitting at a light
Old Feb 3, 2012 | 06:56 PM
  #54
TriplBlk's Avatar
TriplBlk
Mine is a manual and Im pretty sure it idles around 750-800 rpm
Old Feb 3, 2012 | 06:59 PM
  #55
m6 c5's Avatar
m6 c5
Yea Im pretty sure mine is the same and that goes along wit what hp tuners is saying as well.
Old Feb 3, 2012 | 07:04 PM
  #56
TriplBlk's Avatar
TriplBlk
I gotta put a stock tune back in my car but Im too tired lol dangit haha
Old Feb 4, 2012 | 08:19 AM
  #57
m6 c5's Avatar
m6 c5
Well I need to get a wideband so I can tune it corectly
To I give up....
Old Feb 4, 2012 | 09:29 AM
  #58
TriplBlk's Avatar
TriplBlk
I picked up a PLX Wideband for $200 at Jegs
:Cheers:
Old Feb 4, 2012 | 01:17 PM
  #59
m6 c5's Avatar
m6 c5
Ill have to take a look at that.
Old Feb 6, 2012 | 01:02 PM
  #60
cwis9992's Avatar
cwis9992
Posting this up for Cwiss....
The Cause:
ok i temporarily repaired this. but i need a new one. does anyone have any idea where i can get one of these pcv hose end connector thingee's from????
