Adding C6Z51 Sway bars and bilstein HD shocks
Old Feb 1, 2012 | 03:12 PM
MGK's Avatar
MGK
Default Adding C6Z51 Sway bars and bilstein HD shocks
Am adding C6Z51 Sway bars and bilstein HD shocks to a stock 2000 C5 based on threads seen here. What kind of changes will I see in handling? Anything I should also be adding to the car for handling improvements?
Old Feb 1, 2012 | 10:33 PM
Redhawg's Avatar
Redhawg
Metal end links
Old Feb 1, 2012 | 10:38 PM
MGK's Avatar
MGK
yep got those onorder too
Old Feb 2, 2012 | 11:55 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I would also replace the composite springs to the Z06 springs to get the max benefit from the shocks/sways upgrade...
Old Feb 2, 2012 | 12:16 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
If you go with the Z06 springs, then I would also look into wider rims and tires to complete the transition. A set of C5 Z06 rims with stock C5 Z06 tires would be ideal.
Old Feb 3, 2012 | 11:30 AM
MGK's Avatar
MGK
Whats involved with installing Z06 springs? Cost?
Old Feb 3, 2012 | 01:01 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Keep your eyes open as they often come up for sale here on the forum for a few hundred dollars.....not sure on the cost of installation but I would strongly suggest that you take it to a pro. Take a stock Z06 out for a ride and feel the difference..
Old Feb 6, 2012 | 02:25 PM
PetersC5's Avatar
PetersC5
The C6Z51 sways alone will make a remarlable difference in your ride....
I did these on my Y2K and added 2004 C5 Z06 shocks which were pretty stiff. For daily driving, i switched to C6Z06 shocks to soften it up.
To Adding C6Z51 Sway bars and bilstein HD shocks
