How do you check an O2 sensor???
Old May 13, 2002 | 08:43 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default How do you check an O2 sensor???
Any suggestions???????
Old May 13, 2002 | 09:37 AM
Son93SL2's Avatar
Son93SL2
Default Re: How do you check an O2 sensor??? (Mag Red Monster)
<--- I'm stupid. :D How bout just buying one of these bob.
[Modified by Son93SL2, 9:34 AM 5/13/2002]
Old May 13, 2002 | 09:56 AM
Walt Donovan's Avatar
Walt Donovan
Default Re: How do you check an O2 sensor??? (Son93SL2)
"....use a micrometer....." Huh? To get a more accurate reading than using a tape measure?
O-2 does not change resistance as O-2 varies, it generates voltage between ~0 and ~1 volt. Pretty sure Atap will give you voltage output. Voltmeter will also tell. The voltage, at idle, will keep going up and down within this range, indicating the sensor is working and the pcm is correcting to maintain stoichiometric. As far as which wires to tap, maybe someone can help. Can't get to my shop manual right now. If no one posts by later today, I will.
Old May 13, 2002 | 11:02 AM
Mag Red Monster
Elite Member
Default Re: How do you check an O2 sensor??? (Walt Donovan)
thanks Walt
To How do you check an O2 sensor???
