Removing Front Bumper Bezels
Old Feb 3, 2012 | 06:33 AM
Choreo's Avatar
Choreo
Default Removing Front Bumper Bezels
Not sue if that is the correct term for them "bezels"... I am referring to the black concave plastic pieces that surround the fog lights (if you have the fog-light option as I do) that block the air flow from entering the bumper from the front on the right and left side of the license plate.
How hard is it to remove those if you have fog-lights? Does the bumper have to come off?
Old Feb 3, 2012 | 08:57 AM
dougbfresh's Avatar
dougbfresh
Front fascia has to come off, 30 minute job, seems like a wasate of your time though.
Old Feb 3, 2012 | 12:05 PM
corvettebob1's Avatar
corvettebob1
No the fascia doesn't have to come off but it's not a fun job.
I removed mine a long time ago and installed the Z06 screens with real bolts.
You have to access them from the bottom.
Old Feb 3, 2012 | 01:40 PM
dougbfresh's Avatar
dougbfresh
Taking the fascia off IS easier!
Old Feb 3, 2012 | 01:46 PM
chaase's Avatar
chaase
St. Jude Donor '12
If you just want to get some air in there, I used a rotozip to open up the area and then added screens.
Old Feb 3, 2012 | 02:12 PM
PhilsFRC's Avatar
PhilsFRC
There are 3x10mm bolts that hold them in place. Two are one above the other on the inboard side (near the front plate holder). The other goes vertically through a tab in the assembly and also serves to attach the inner side of the front turn signal mount. This one can be reached (with difficulty) by pushing the brake duct out of the way. For me, the center ones were easy--I was in the process of cutting a hole behind the plate cover to install a screened cover. Your results will vary. And BTW, there are two tabs on each one that support the wiring harness that runs across the nose. Unless you're installing z06 screens (that also have the tabs on them), you'll need to figure out what to do to support the harness.
Old Feb 3, 2012 | 02:22 PM
PhilsFRC's Avatar
PhilsFRC
Here's an exploded parts diagram to help you visualize this. You need to remove bolts 35&37 on each side:
http://parts.nalleygmc.com/showAssem...&searchString=
Old Feb 3, 2012 | 09:32 PM
Choreo's Avatar
Choreo
I am just wanting to remove them to get them Hydrocarbon dipped, then re-install.
Old Feb 4, 2012 | 11:50 AM
corvettebob1
Yes this is a good point, it's the harness that triggers the SIR.
To Removing Front Bumper Bezels
