When to adjust belt tensioner?
Old Feb 4, 2012 | 11:54 PM
CaryKen's Avatar
CaryKen
Default When to adjust belt tensioner?
I am not a DIY guy when it comes to engines. I just had my mechanic install a Katech belt tensioner to replace the original (at 100K miles), which had developed the famous "cold morning chirping" problem.
This aftermarket tensioner is not auto-adjusting. You position it to achieve the recommended pounds of tension on the belt.
My question is whether the tension adjustment is something that needs to be checked regularly, at a certain number of miles interval, or left alone until/unless you start hearing belt slippage?
Thanks for the help.
Old Feb 5, 2012 | 02:54 AM
cdkcorvette7's Avatar
cdkcorvette7
Manufacturer's installation instructions say to check it periodically: http://www.katechengines.com/street_...structions.pdf
Personally I'd check it every couple of months...
