Rear Tie Rod Ends
Old Feb 7, 2012 | 10:35 AM
nagroves's Avatar
nagroves
6th Gear
Default Rear Tie Rod Ends
I've done my front tie rod ends now its time for the rear. I noticed the rear tie rod ends were longer then the front and everyone that sells the rear tie rod ends they are shorter making it useless to count threads to even get it close... ANY HELP?
Old Feb 7, 2012 | 12:32 PM
tentuna's Avatar
tentuna
I would not use front tie rod ends on the rear, you will not get enough thread engagement vice verse if you use the rears on the front there will not be enough adjustment. There are two different PN's for front and rear.
