check engine lite on
Old Feb 9, 2012 | 05:31 PM
dewaynemichael's Avatar
dewaynemichael
Default check engine lite on
two weeks ago the check engine lite came on ,i had it checked and they said it was my gas cap,changed it,today the check engine lite came on again,had it checked, they said it could be the canister purge vavle solenoid,but before i change it to get a smoke test,what do you think?
and where is the canister purge valve solenoid located? im driving a 2002 c5,thanks
Old Feb 9, 2012 | 06:00 PM
David Shiel's Avatar
David Shiel
Default What codes
do you have on the DIC? Codes should eliminate the guess work or narrow down the search parameters. Always start with the codes.
Old Feb 9, 2012 | 06:08 PM
hotwheels57's Avatar
hotwheels57
Once you get the codes off the DIC (H=history, C=current), then check here to begin narrowing down the problem(s)...
http://www.stengel.net/diccodes.htm
Old Feb 9, 2012 | 08:30 PM
dewaynemichael
ok,i/ll do that,thanks
Old Feb 9, 2012 | 10:42 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by 8VETTE7
Pull the codes using the link above. Write them all down including the H or C or HC that follow the code.
If you have more than 6 or 8 codes, clear them all (info in the link on how to do that) and then drive the car a bit and then pull the codes again. Those that come back are the one you need to deal with.
I'm assuming based on the diagnoses that you have a code for an EVAP leak; telling us which one it is will help. I HATE it when shops just throw parts at a car until you get the problem fixed without employing proper diagnostics...
When you replaced your gas cap did you use OEM or aftermarket?
Also, before you do anything else or pay anyone else for any diagnostics pull your driver's side fuel rail cover and locate the plastic braided evap line that runs along the motor. near the coil packs. That line has a small green screw-cap in it (it may be grayish looking due to discoloration over the years) make sure it's screwed on firmly. I've seen a couple of those that have come loose all on their own and as a result the cars threw EVAP leak codes. While you have the cover off inspect that line for cracks and/or breaks.
Also please post ALL of your DTC's and be sure to include the H or C suffix that follows them.
To check engine lite on
