Need help with this mess
Old Feb 10, 2012 | 02:12 PM
coop875's Avatar
coop875
Default Need help with this mess
A buddy and myself were installing longtubes on his car and everything went smoothly, but when we connected the battery after everything was complete, several things happened:
fans automatically came on, and never turned off, no key in ignition
screen flashed reduced engine power, also said service engine soon
and after all that it isn't starting, I am assuming its an electrical issue, just lost right now
then the DIC gave a slew of codes all which said no connection next to them
BO-RFA
10-PSM
28-TCS
40-BCM
58-SDM
60-IPC
80-RADIO
99-HVAC
A0-LDCM
A1-RDCM
I have no idea what to do and we need to get it running soon, any help is much appriciated
Old Feb 10, 2012 | 02:27 PM
dougbfresh's Avatar
dougbfresh
Clear them all and see how things go, make sure the battery has a good charge on it too.
Old Feb 10, 2012 | 03:16 PM
bumble-z's Avatar
bumble-z
I would bet that it's a low/dead charged battery.
Trickle charging the batteries, when car is not in use, are the C/5's electrical systems "best friend".
Old Feb 10, 2012 | 03:17 PM
coop875's Avatar
coop875
done, but the pcm-10 no connections still shows up, and the fans still kick on when I remove the key, even though the car has been off for 12 hours
Old Feb 10, 2012 | 03:19 PM
coop875's Avatar
coop875
when the battery is connected I can turn the engine over just fine, everything works, just doesnt actually start
Old Feb 10, 2012 | 03:31 PM
hotwheels57's Avatar
hotwheels57
Did you remove the starter for the installation? Have you inadvertently left solenoid wires disconnected?
Old Feb 10, 2012 | 03:33 PM
coop875's Avatar
coop875
I did remove it but no everything is connected, 4 wires on the big bolt and the one on the small one
Old Feb 10, 2012 | 05:22 PM
ICUALL's Avatar
ICUALL
Default Fyi
FYI - The list you have only shows all the modules checked by the dic i.e . PCM - Power Control Module The codes will be 4 digits with a H (history) or C (current) at the end - i.e. P0401H
Might start here - http://www.c5help.com/c5_no_start.htm
Old Feb 10, 2012 | 06:36 PM
sean.b's Avatar
sean.b
unless you pulled sensors off or forgot to plug some back in, its gotta be the starter. take a breather, drink a beer, and double check anything made out of or containing plastic.
Old Feb 10, 2012 | 11:38 PM
coop875's Avatar
coop875
I was thinking starter,will report back monday, out of town for a gun show, thank you gentlemen!!
Old Feb 10, 2012 | 11:43 PM
coop875's Avatar
coop875
haven't looked at the car but I am quite sure one of the ground wires is actually on the starter, almost positive thats what it is
Old Feb 13, 2012 | 01:30 PM
coop875's Avatar
coop875
Does the red wire go on first? it looks like that in the picture below
Old Feb 13, 2012 | 07:49 PM
coop875's Avatar
coop875
wires were the issue, car runs great
To Need help with this mess
